heater not blowing - JeepForum.com
post #1 of 8 Old 08-31-2010, 09:52 AM Thread Starter
ronniez
heater not blowing
so i checked the fuse and replaced the resistor but my 95 wrangler yj 2.5 will not blow any air. I feel the heat coming through the vents but not blowing out could it be the actual blower motor went sour?
ronniez is offline
post #2 of 8 Old 08-31-2010, 10:29 AM
Que89YJ
Welcome to the forum. You need to check for power on the blower motor connector. Its easy to geat at. look on the fire wall just below the battery and with the blower on use a test light to see if you have power. If you do then you need to replace the blower.
Que89YJ is offline
post #3 of 8 Old 08-31-2010, 11:01 AM Thread Starter
ronniez
will check it out thanks for the quick reply!
ronniez is offline
post #4 of 8 Old 09-06-2011, 01:05 PM Thread Starter
ronniez
just an update it turns out i was not getting power to the connector so i jumped power to motor and still no spin. I traced the power from the fuse box to the hi low switch behind the heater assembly and found ridiculous amounts of corrosion on the hi low switch and connector. i cleaned the switch and the connector and wamo! we have juice. I then put a test light to the connector to the motor and now i had juice. So i bought a new blower installed it this past weekend and we finally have heat for the winter!
ronniez is offline
post #5 of 8 Old 09-06-2011, 02:16 PM
Que89YJ
Thanks for posting back the fix.
Que89YJ is offline
post #6 of 8 Old 09-06-2011, 05:57 PM
pasinbuy
Sorry guys, I just can't help it!
You don't need no heater, just open the windows and enjoy the fresh air.
I can't tell you how many times someone here has said this about AC. In S. Florida we rarely use the heater, the AC if we have it we it use allot.
Felt kind of good, thanks for letting me vent a bit.
Martin
pasinbuy is offline
post #7 of 8 Old 09-07-2011, 07:41 AM Thread Starter
ronniez
haha here in new york a heater is definately needed but i hear where your coming from
ronniez is offline
post #8 of 8 Old 10-02-2011, 02:02 PM
schultisdj
I am havin same problem with 2000 wrangler replaced all fuses behind glove box and fan control switch so wat else could it be thanks in advance
schultisdj is offline
Heater is always blowing renegadeyj YJ Wrangler Technical Forum 3 08-18-2010 09:01 AM
Heater blowing but blowing hard fireman879 TJ Wrangler Technical Forum 2 12-29-2009 09:08 PM
Heater not blowing hot Marholmes44 TJ Wrangler Technical Forum 1 12-17-2008 12:46 AM
Heater fan blowing air fireman413 TJ Wrangler Technical Forum 1 12-10-2008 06:20 PM
heater not blowing out hot air?? stewart20 TJ Wrangler Technical Forum 1 03-01-2003 03:08 PM
