Quantcast heater gone dead - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > heater gone dead
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 12-16-2007, 12:08 AM   #1
blurunner
1930 YJ Wrangler
heater gone dead
my heater went dead on me. It was working one moment and then pooped out. I've checked the fuses under and it's all okay so I'm stumped on this. Any suggestions??
thanks.
blurunner is offline   Reply With Quote
Old 12-16-2007, 12:43 AM   #2
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Did you check the wiring that connects to the blower motor on the inside and the one just below the batt tray??? That one can come off.
Start testing your wiring to the heater with a multimeter. If you have juice but no heat then I would start with the blower motor itself. If you search, you will see one of 15 threads in the last few weeks on the blower motor replacement and upgrade.
-Rusty
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 12-16-2007, 09:45 AM   #3
Jeep25
How about checking the Resistor?. That has been known to go bad and if it does, the heater will only work on the high speed.
Jeep25 is offline   Reply With Quote
Old 12-18-2007, 03:26 AM   #4
blurunner
1930 YJ Wrangler
Here's the thing...If I pull up firmly all the way up on the fan speed lever, the heater will turn on. Is that the cause of the resistor. If so, where would the resistor be located?
Old 12-18-2007, 07:25 AM   #5
MetZenDS
You need a haynes manual. It has most of that fun stuff in it. Great book- and you can get it at most parts stores for ~$15-20
1989 Jeep Wrangler YJ- PARTING OUT- http://www.jeepforum.com/forum/f149/89-yj-part-out-862198/
MetZenDS is offline   Reply With Quote
Old 12-18-2007, 07:33 AM   #6
ss313
If you have to hold pressure on the fan switch it mat be the bad part. If you only need to put it in the high setting for the fan to work the resistor is the most likely suspect.
Scott
95 YJ 2.5, 5 spd., 8.8, 2" lift, 30's = fun
78 Chevy K10 7" lift, 35's, 350 = intimidation
ss313 is offline   Reply With Quote
Old 12-18-2007, 01:02 PM   #7
OneLung
It may just be a dirty switch. Take it out and clean the switch with some 91% rubbing alcohol and a tooth-brush.
[URL="http://www.wrangleryj.net"]Used YJ Parts - Hundreds to Choose From![/URL]
OneLung is offline   Reply With Quote
Old 12-18-2007, 01:43 PM   #8
pat8942
The resistor pack for the Jeep YJ is located beneath the dashboard on the passenger side. It's a "Rectanguler shaped" piece of red plastic, held on by two screws. There is a 4 wire connector visible as well.
Its just above the vent door.
thanks.
pat8942 is offline   Reply With Quote
Old 12-22-2007, 09:01 AM   #9
hanshunter
hanshunter's Avatar
You guys on this forum are allot of help.
I just recently purchaced a 95 wrangler and have a few
little issues with it and can always seem to find an answer
somewhere here!! Thanks
hanshunter is offline   Reply With Quote
Old 10-06-2008, 04:35 AM   #10
blurunner
1930 YJ Wrangler
I've looked under the dash and could not locate anything red w/ 2 screws or a 4wire connector as well. This was all I could locate that was similar to the description mentioned. Is this the correct unit?
[IMG][/IMG]
[IMG][/IMG]
Old 10-06-2008, 11:41 AM   #11
timatoe
Jello Puddin'
timatoe's Avatar
No, that's a relay. Try cleaning the switch first and check the electrical connections, then look to the resistor. Typically with electrical parts such as a resistor, it either works or doesn't, they don't go kinda bad.
Originally Posted by jbolty View Post
... never underestimate the idiocy of Nancy Pelosi...
timatoe is offline   Reply With Quote
Old 10-07-2008, 02:00 AM   #12
blurunner
1930 YJ Wrangler
I've already cleaned the switch and checked the connections. Would you happen to know of the exact location of the resistor pack? I've looked and looked but don't see anything like the described.
Old 10-07-2008, 11:31 AM   #13
timatoe
Jello Puddin'
timatoe's Avatar
I wouldn't be able to describe the location any better than Pat already did. Did you check the voltage?
Old 12-16-2010, 07:58 PM   #14
Todd14
I have had the same problem with my '95 YJ. I replaced the resister and that didnt help. It is right to the left of the interior light just to the left of the light switch (Shuts off light when door opens or closes) on the passinger side. Just under the dash. I had a hard time locating it first my self. Mine was all black
Todd14 is offline   Reply With Quote
Old 12-28-2010, 12:22 AM   #15
brutus_skx
Ok I have a question; why don't people post more pictures on this site? It seems all are very knowledgeable about locations and what to do, but if someone doesn't know where something is (like me) is it too hard for a quick picture to be posted to help us? Perhaps someone could post a picture of this resistor pack they speak of to help others out a little more that just a typed description?
I'm a noob to this site but I have been on wheeling forums for about 4 years now (had a 2006 Nissan Xterra and wheeled the piss out of it and use to be on thenewx.org all the time), so I'm not trying to flame anyone or come across as an @$$. Just would like some visuals posted that can help the ones new to jeeps out while we are trying to find our way around these old things. Some have to try and decipher what is factory vs mods vs what was totally removed. Any help from you older fellas who knows these things in and out would be greatly appreciated.
'93 YJ on 33" with SOA lift.
Go BSU!!
brutus_skx is offline   Reply With Quote
Glock Forum
