Heater Fuse Keeps blowing - JeepForum.com
post #1 of 2 Old 12-11-2003, 08:19 AM Thread Starter
RSouth
My heater fuse keeps blowing. I think I have a wire loose that is shorting out the connection. I do not know where it is. Am I on the right track? Is there anything else I need to look for?
Thanks
RSouth
RSouth is offline
post #2 of 2 Old 12-11-2003, 04:05 PM
KEVNISE
Thanks
RSouth
I think your right on track you have either a burnt wire or its grounding out on something trace the wire there are only a couple on the heater
90 wrangler weber carb nutter bypass 4" lift pro comp 4.2 liter 33" muds 411 gears
69 camaro
KEVNISE is offline
Heater blowing but blowing hard fireman879 TJ Wrangler Technical Forum 2 12-29-2009 09:08 PM
Fuse blowing tonylax48 YJ Wrangler Technical Forum 3 08-12-2009 09:56 PM
'94 Keeps Blowing Fuse ThatHumble YJ Wrangler Technical Forum 11 06-09-2008 05:36 PM
heater fuse keeps blowing blamejane2 YJ Wrangler Technical Forum 8 04-27-2008 04:10 PM
blowing my fuse garbo1954 YJ Wrangler Technical Forum 15 03-28-2005 11:11 PM
