heater fuse keeps blowing - JeepForum.com
post #1 of 9 Old 04-25-2008, 06:14 PM Thread Starter
blamejane2
I just replaced the blown fuse for my heater. With a new fuse in place I tried the heater, and again nothing...sure enough I've blown another fuse. After installing another fuse I started the jeep and then stopped it (without turning on the heater). I checked and the fuse was blown again, just by starting the jeep.
Does anyone have an ideas where/what I should look at?
blamejane2 is offline
post #2 of 9 Old 04-25-2008, 09:50 PM
coshooter
2009 JK Wrangler
Possibly a bad switch that's got an internal short. If you use an ohm meter and test from the switch side of the fuse plug (not the side with 12v coming from the battery) to a ground on the jeep and have continuity that would indicate a short either between the fuse and the switch or in the switch itself.
coshooter is offline
post #3 of 9 Old 04-25-2008, 10:02 PM Thread Starter
blamejane2
Thanks coshooter. How do I tell which side of the fuse plug is the switch side, versus the side coming from the 12v battery)?
post #4 of 9 Old 04-26-2008, 05:37 PM
xeroid81
Are you putting the right amp fuse in there?
xeroid81 is offline
post #5 of 9 Old 04-26-2008, 06:16 PM Thread Starter
blamejane2
yes, it calls for 25 amps.
post #6 of 9 Old 04-26-2008, 07:58 PM
coshooter
2009 JK Wrangler
Use a test light or voltmeter and see which side of the fuse plug has 12v to a frame ground with the key in the on position.
post #7 of 9 Old 04-27-2008, 08:48 AM
xeroid81
It sounds like a short to the motor from the switch or the relay if it's on the load side.
xeroid81 is offline
post #8 of 9 Old 04-27-2008, 01:18 PM Thread Starter
blamejane2
I have continutiy at the fuse when testing the switch side. I disconnected the heater switch and checked again, the fuse still has continuity. I disconnected the a/c switch and still we have continuity.
Any ideas?
post #9 of 9 Old 04-27-2008, 04:10 PM Thread Starter
blamejane2
There's supposed to be a diode tapped in the wiring harness somewhere near the wiper switch t/o.
Does any one know where this diode is? I need to see if this diode was blown when my pcm fried. I'm trying to trace fuse #12 dk green wire, which is supposed to have a diode.
Any help would be awesome.
Heater blowing but blowing hard fireman879 TJ Wrangler Technical Forum 2 12-29-2009 09:08 PM
Fuse blowing tonylax48 YJ Wrangler Technical Forum 3 08-12-2009 09:56 PM
'94 Keeps Blowing Fuse ThatHumble YJ Wrangler Technical Forum 11 06-09-2008 05:36 PM
blowing my fuse garbo1954 YJ Wrangler Technical Forum 15 03-28-2005 11:11 PM
Heater Fuse Keeps blowing RSouth YJ Wrangler Technical Forum 1 12-11-2003 04:05 PM
