Heater doesn't work - JeepForum.com
post #1 of 9 Old 03-11-2005, 11:42 PM Thread Starter
The Fuzz
The Fuzz's Avatar
Heater doesn't work
Hey guys...
On my way home from work tonight my heater just stopped working. I turned it on hi to deforst the window and it was blowing out fine. About half way home I noticed it wasn't blowing hard any more. I played with all the controls and nothing happend. The air comming out of the vents was still hot, but it wasn't blowing hardly any air at all. Has this ever happend to anyone? If so what caused it and whats the best way to fix it?
Thanks guys..
2000 Jeep Cherokee Sport
1995 Jeep Wrangler Sahara
The Fuzz is offline
post #2 of 9 Old 03-12-2005, 05:55 AM
drew2000
drew2000's Avatar
Check to see if the blower kicks on when in Low or Medium mode. If it doesn't work in High mode but does work in the other two, you have a problem with the connection to the blower motor resistor.
<edit>it could also be a fuse to the blower motor, if there is one...
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #3 of 9 Old 03-12-2005, 12:00 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Since you say you played with the controls I'd say it sounds like the blower motor itself died, assuming the fuse didn't blow... On mine actually, when the motor was dying last year, it would spin for a while but gradually slow down and heat up to the point that it would blow the fuse anyway. Some air would still blow out the vents when I was moving though, since air would hit the cowl vent and force its way through the system. That's probably the warm air you're feeling.
I eventually did the Blazer motor upgrade, but I don't know if that applies to the newer YJs. Anyway, replacing the motor is not too hard at all. Biggest pain is getting that heater assembly out, but it's doable.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #4 of 9 Old 03-13-2005, 06:06 AM
pyro9862
Unplug the blower, put a test light on it. If it's not getting voltage start tracing wires. If it is make sure it is turned on (controlls not broken). If it's turned on and getting voltage the motor is dead. I think you could directly apply the 12v to it to check the motor as well unless their is a resistor somwhere?
pyro9862 is offline
post #5 of 9 Old 03-13-2005, 07:28 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I believe on the high setting, the blower is recieving full voltage from the battery. It's only on the lower speeds that it goes through resistors, so you could test it by applying voltage to it.
post #6 of 9 Old 03-13-2005, 10:05 AM
JPH
JPH's Avatar
Let me know if you need to get to the motor. I replaced my heater core last weekend and took pictures. Had it back together in about 3-4 hours at a slow pace. Easy job, and mine has the under-dash AC unit.
'95 YJ 4.0L/AX-15
JPH is offline
post #7 of 9 Old 03-13-2005, 01:31 PM
bono426
bono426's Avatar
can you send me the pictures? i have to replace my blower motor too and im not to sure where to start.. thanks
1998 ZJ (What in the heck is a ZJ?)
5.2 V8
bono426 is offline
post #8 of 9 Old 03-15-2005, 09:23 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Originally Posted by JamesHastings
Did this help?
It helped me! Thanks for giving me something new to add to my favorites list
post #9 of 9 Old 03-15-2005, 09:31 PM
JPH
JPH's Avatar
Good! I'm glad it helped. I put a little time in it since it seems like a lot of people have asked about it, and I just didn't want it to get lost without anyone seeing it.
'95 YJ 4.0L/AX-15
JPH is offline
Heater won't work..? jeep_freek TJ Wrangler Technical Forum 2 04-06-2011 12:11 AM
heater fan does not work?? bjbrowder YJ Wrangler Technical Forum 18 11-26-2010 07:46 PM
A/C and Heater don't work!! kx97250 TJ Wrangler Technical Forum 2 09-11-2009 07:31 AM
My heater won't work??? byrdi TJ Wrangler Technical Forum 14 02-19-2009 07:23 PM
How does the heater work? AustinJeep TJ Wrangler Technical Forum 14 11-05-2006 09:14 PM
