Heater Core - Page 2 - JeepForum.com
post #16 of 26 Old 07-31-2013, 03:42 PM
tom_sprecher
If you can get a brass like OEM one they are the best. After a couple of tries at NAPA and getting cores with no bracket I finally got an aluminum one that had the brazed on bracket from Amazon for $59 shipped. It is not as good as OEM since the bracket is soft aluminum and easy to strip when tightening down the two mounting screws. The OEM bracket was steel soldered to the end tank.
Tom
tom_sprecher is offline
post #17 of 26 Old 07-31-2013, 03:45 PM
XJ93
You might not think so but it does reach the water table eventually even through evaporation. If 100 people felt that their local waste water plant could handle the amounts "we produce" that's 400~ gallons of coolant being dumped. Do you really think that's okay? How hard is it to take your used coolant to a local mechanic who probably has someone that picks it up and recycles it?
XJ93 is offline
post #18 of 26 Old 07-31-2013, 03:55 PM
bpounds
bpounds's Avatar
We're getting way OT here, so I won't belabor, except to say that you said it was illegal, which is not necessarily the truth.
bpounds is offline
post #19 of 26 Old 07-31-2013, 04:25 PM
XJ93
I know I am off topic, but it is illegal as per all states. I'll leave it at that.
XJ93 is offline
post #20 of 26 Old 07-31-2013, 05:05 PM
debord97
Well to play it safe since the heater hoses are long enough you can stick them in a jug to catch all the fluid. See what I did there? Simple fix.
debord97 is offline
post #21 of 26 Old 08-01-2013, 11:42 PM Thread Starter
AristosIV
How do I contact Chicago Deltas
Bears camp is ok, if you plan to go, know that the I57 Bourbonnais exit is a construction nightmare and the posted routes suck. Let me know and I'll give you directions and pointers
AristosIV is offline
post #22 of 26 Old 09-10-2013, 09:50 AM Thread Starter
AristosIV
New problem
My yj 2.5 runs rough
Low power plugs good,injectors good, etc, no one autozone, etc claim they can't scan it
post #23 of 26 Old 09-10-2013, 03:23 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by AristosIV
New problem
They have odb2 readers the Yj is odb1. There is a key turn cycle to pull codes I can't remember it off the top of my head and searching is a pain on my phone.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #24 of 26 Old 09-10-2013, 03:47 PM
SeanB95YJ
key positions are ACC - OFF - ON - START
grab yourself a pencil and paper and sit in the Jeep
turn the key back and forth fairly quickly (WITHOUT STARTING)
ON - OFF - ON - OFF - ON .... now leave it in the on position and watch the check engine light it'll flash the codes
like - flash, pause, flash, flash, longer pause then another code
that example would be a code 12 (write em down, you might have several if there are problems) followed by whatever other codes
the last code should be 55 (5 flashes, pause, 5 flashes) that means end of codes
if you ONLY get a 55, then there are no trouble codes to be had
once you get whatever codes are stored, come back inside and go to Google and search "Jeep YJ check engine codes" for several sources listing all the possible codes
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #25 of 26 Old 09-10-2013, 06:44 PM
bigbossd1030
Here's the list
I have them as photos so if I don't have Internet I can still see them.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #26 of 26 Old 09-10-2013, 10:19 PM Thread Starter
AristosIV
Thank you !!!!!!!!
