Heater Control Cables - JeepForum.com
post #1 of 10 Old 08-08-2011, 09:06 AM Thread Starter
lumpymike
Does anyone have a source for the Small Plastic Clips that connect the Heater and Plenum cable's to the Heater Control Assembly on my 88YJ? I broke one of mine while replacing the Heater Control assembly and I do not think my quick fix is going to hold. They connect the Cable ends to the top of the Control assembly.
lumpymike is offline
post #2 of 10 Old 08-08-2011, 09:32 AM
Que89YJ
Mike those clips arent available. if you look real hard you can find cables on EBAY or a few Jeep specialty places. I think everyone here who has done the HVAC has had the clips break. There is a real easy way to fix it though. I took a dremel and cut 2 slots on either side of the cable just behind where the clip snaps in. I took the cable and put the table in the whole and took small tie wraps and put it through the small cuts I had made and around the cable. It took me 30 minutes to repair and I never have to worry about the cables again.
Que89YJ is offline
post #3 of 10 Old 08-08-2011, 09:36 AM
Matt24138
I think I have one I can spare pm me. I will look I could send it to you.
Matt24138 is offline
post #4 of 10 Old 08-08-2011, 09:48 AM Thread Starter
lumpymike
If I follow you correctly, Notch the "cable"? I just might pull the HVAC out and take a look. Thanks for the information.
post #5 of 10 Old 08-08-2011, 11:06 AM
Tallpaul
A buddy of mine came up with the idea to drill a small hole in the flat part of the control on either side of the plastic piece and use a small tie-wrap through the holes and over the plastic end to hold it in place. Worked pretty well.
Tallpaul is offline
post #6 of 10 Old 08-08-2011, 11:14 AM Thread Starter
lumpymike
Appreciate the tip.
Thank you
post #7 of 10 Old 08-08-2011, 11:24 AM
Que89YJ
I know its been done. I just wish I had pics.
Que89YJ is offline
post #8 of 10 Old 08-08-2011, 11:26 AM
Tallpaul
No pics of actual repair. I have a control for reference, I'll see if I can sketch something up tonight.
Tallpaul is offline
post #9 of 10 Old 08-08-2011, 12:01 PM
Redlightracer
I fixed mine with zip ties ! easy and fast !!
Redlightracer is offline
post #10 of 10 Old 08-08-2011, 12:20 PM Thread Starter
lumpymike
Thanks for all the help Guys, really do appreciate your ideas.
YJ Heater Control Cables wranglerX3 YJ Wrangler Technical Forum 1 12-06-2010 07:33 AM
Heater control cables... weirdodaddy YJ Wrangler Technical Forum 4 10-17-2010 09:46 AM
Heater Control Cables Que89YJ YJ Wrangler Technical Forum 4 04-11-2009 07:19 AM
Heater control cables help please... gqscuba YJ Wrangler Technical Forum 0 12-13-2008 11:27 PM
Heater Control Cables Tallpaul YJ Wrangler Technical Forum 2 04-16-2006 09:51 PM
