Heater Box Adjustment - JeepForum.com
post #1 of 6 Old 09-06-2011, 01:41 PM Thread Starter
kjg26
kjg26's Avatar
In the process of some trouble shooting I removed the heater box/selector at the passenger side foot area. Where should it be adjusted to for proper operation? When the vent selector is all the way to the left what position should the door be in? At what point should the door begin moving and when the selector switch is all the way to the right where should the door be? This is a NON AC model
Thanks
Keith
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 6 Old 09-06-2011, 02:06 PM
Berniebikes
look in the frequently asked questions sticky, the operation of the heater controls is fully explained.
Berniebikes is offline
post #3 of 6 Old 09-06-2011, 02:08 PM Thread Starter
kjg26
kjg26's Avatar
wonderful thanks!
kjg26 is offline
post #4 of 6 Old 09-06-2011, 06:03 PM Thread Starter
kjg26
kjg26's Avatar
I didn't see anything on the proper adustment of the box and lever. I see lots of info on the operation and how to fix gummed up wires, but nothing on How to properly set the doors/wires.
kjg26 is offline
post #5 of 6 Old 09-06-2011, 08:27 PM
Berniebikes
Check out this thread from the FAQ page. On around page 3 there is a complete description on how the heater controls and vacum actuator work to open and close the two doors. The thread is old so many of the pictures are not there, but the info and descriptions should be sufficient. If that doesn't work and you have a specific question then post it back.
http://www.jeepforum.com/forum/f12/m...es-why-499877/
post #6 of 6 Old 09-07-2011, 01:58 PM Thread Starter
kjg26
kjg26's Avatar
Originally Posted by Nitrox73 View Post
When your controls are set to defrost/heat
Your blower motor will now be energized with three speeds, the vent door inside your hood intake on the passenger side only will be open, and the inside vent will be shut
Passenger Side-Open
Driver Side-Closed
Inside Vent-Closed
which items are these referring to? passenger side vent, drivers side vent, inside vent, vent door inside hood intake?
kjg26 is offline
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
heater help: not the usual heater problem doug davis TJ Wrangler Technical Forum 2 12-06-2010 05:34 AM
TF-904 Adjustment Rubidon1994 YJ Wrangler Technical Forum 0 10-09-2010 06:18 PM
Reverse heater lines at intake 4.2 (front to heater core/ rear to bypass port) Chris Aunchman YJ Wrangler Technical Forum 1 07-27-2010 01:16 PM
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
