-   -   Heater Box Adjustment (http://www.jeepforum.com/forum/f12/heater-box-adjustment-1261900/)
kjg26 09-06-2011 01:41 PM
In the process of some trouble shooting I removed the heater box/selector at the passenger side foot area. Where should it be adjusted to for proper operation? When the vent selector is all the way to the left what position should the door be in? At what point should the door begin moving and when the selector switch is all the way to the right where should the door be? This is a NON AC model
Thanks
Keith
Berniebikes 09-06-2011 02:06 PM
look in the frequently asked questions sticky, the operation of the heater controls is fully explained.
kjg26 09-06-2011 02:08 PM
wonderful thanks!
kjg26 09-06-2011 06:03 PM
I didn't see anything on the proper adustment of the box and lever. I see lots of info on the operation and how to fix gummed up wires, but nothing on How to properly set the doors/wires.
Berniebikes 09-06-2011 08:27 PM
Check out this thread from the FAQ page. On around page 3 there is a complete description on how the heater controls and vacum actuator work to open and close the two doors. The thread is old so many of the pictures are not there, but the info and descriptions should be sufficient. If that doesn't work and you have a specific question then post it back.
http://www.jeepforum.com/forum/f12/m...es-why-499877/
kjg26 09-07-2011 01:58 PM
Originally Posted by Nitrox73 (Post 4639287)
http://www.jeepforum.com/gallery/fil...6912_0_ALB.jpg
When your controls are set to defrost/heat
Your blower motor will now be energized with three speeds, the vent door inside your hood intake on the passenger side only will be open, and the inside vent will be shut
Passenger Side-Open
Driver Side-Closed
Inside Vent-Closed
which items are these referring to? passenger side vent, drivers side vent, inside vent, vent door inside hood intake?
The time now is 07:14 PM.
