My heater blower is constantly running but when I move the control up and down for fan speed it does nothing? Don't know if this is related but I found two wires with terminal ends in the engine bay along the left side top of the motor not connected to anything. They look as though they should be going to the carb but can't find anywhere they should be plugged into.
Its a set of heavy duty resistors mounted on a "block" that sorce the current from the 12VDC supply of the car to change the blower speed. Its a common fail part. Due a quick search and you should have no problem finding the info to replace it.
Actually, mine runs all the time too unless I shove something under the selector lever in the OFF or VENT positions. Mine is just a worn out switch, (better always on than always off!:rofl. The speed selector still works, which is a good way to diagnose the resistor.
You have a good point. Is it on even with the switch in the off postion? His post says that speed doesn't vary with the speed switch, but a short across the switch will do the same thing. If the off switch is functional it still makes sense that its the Resistor block. If the control switches do nothing, then it is probably the switch.
If the resistor is bad, it will always run on high, but may be burnt out for some or all of the lower speed settings. In that case it wouldn't run at all on some or all of the lower settings. I would guess that your switch is bad. Also, there is nothing in the engine compartment that would have any effect on this.
You know I didn't think so. It just seemed very strange that all of a sudden my fan speed isn't working and I find 2 wires unplugged in the engine bay.
Would these resistors be put in plane sight or do I need to remove the gloveboz or other parts?
Thanks for all the help guys! It's getting cold and I'm taking her on a 6-hour trip each way this weekend!
Passenger side, inside the Jeep, below the glove box, just above the vent grill in the heater box. you'll see a plug with some wires that plugs onto the ductwork. Un plug it and remove the 2 screws holding the resistor block in place.
The only think I found is a 3-pronged plug. If that's it then I don't know what a resistor looks like.
I am thinking that it may be the switch. A couple of weeks ago I had a toggle switch burn out and cause a linkable fuse to blow. I then took the dash apart and the heat control unit out. I may have damaged something then????
The purpose of the resistor block is to source current for the blower. A fuse is a current device that blows when current draw across a circuit is too high to protect wiring (most people think the fuses are to protect the electronic and electrical devices on a vehicle, by design the electrical components are considered expenable) If the fuseable link was blowing the most probable cause was the resistors because they are current devices. Check the resistor block.
The fusable link that blew was because of a burnt out toggle switch (although it may somehow pf been connected with the heater???). What does the resister look like? The resisters I saw were in the engine bay on the far right side next to the battery. 2 of them both a 1" square black with like 6 leads off them.
This is it... Did you check the controls? the fan switch has a lever switch on it so when you move the control to off or vent it turns the power off to the blower motor
I need to find a schematic online to identify all these parts you are telling me about. This is my first Wrangler and have only had it for 3 months so I am kind of ignorant to repairing it. At this point I am getting very frustrated and don't know what to do! I found one of the tiny air hoses that goes into a yellowish part behind the fan switch out. There is 3 ports for the hoses to go into and only one is in and I only found 1 other next to it. Not sure which one it goes into.
Ok so I found the resister and removed it. There are no breaks in the springs, just a lot of rust. I'm going to clean them up and hope that does the trick. As far as the switch and lines, I'm still trying to figure that out.
Is there a relay in that circuit somewhere guys? That sure sounds like a shorted relay, but I don't recall one in there. Never had a blower prob. on the jeep!
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
