heat/vent fan not working - JeepForum.com
post #1 of 9 Old 04-26-2007, 07:53 PM Thread Starter
olyjeep
I haven't used the heat or fan in general for a few weeks but when I was running hot the other day, I went to turn the heat on to see if that would cool it off a little. Low and behold, the fan is not working at all on any speed.
Only thing I did recently was to pull the gauge cluster to clean the contacts on the oil pressure gauge but I don't think I messed anything up below it.
I checked the fuse and it is ok, and I pulled and inspected the connector behind the fan switch, seems to be connecting ok.
Any other things I should check?
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #2 of 9 Old 04-26-2007, 09:42 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
What setting do you have it set on? If its on vent it does not blow air on that setting.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 9 Old 04-27-2007, 08:14 AM Thread Starter
olyjeep
I tried it on all the settings but still no fan.
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #4 of 9 Old 04-27-2007, 08:33 AM
ltdanyj
I just had the same problem yesterday!!! turn your key on, but don't start your engine... Now turn your heater/fan on, and watch your voltmeter. Does it drop? If so, your motor is jammed... I pulled the blower cover, and found a PEN that looked 10 years old.... Everything is hunky dory now....
ltdanyj is offline
post #5 of 9 Old 04-27-2007, 09:10 AM Thread Starter
olyjeep
Hmmm, I'll have to check that out. Where is the blower motor located at anyway? I don't have the Jeep nearby right now.
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #6 of 9 Old 04-27-2007, 09:43 AM
ltdanyj
passenger footwell, next to the kickpanel
ltdanyj is offline
post #7 of 9 Old 04-27-2007, 10:53 AM Thread Starter
olyjeep
Thanks! I'll check when I get home today.
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #8 of 9 Old 04-27-2007, 10:02 PM Thread Starter
olyjeep
Tried it and voltage does not drop at all. On to the next step. anyone else know what may have caused this? It was working a month ago...last time I needed the heater anyway...
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #9 of 9 Old 04-28-2007, 09:41 AM
timatoe
timatoe's Avatar
Open the hood and look under the battery, you'll see the back of the blower motor sticking through the firewall. It should have a orange (I think) wire on a spade terminal. If it's not there = no power to the motor. Guess how many ways I tried troubleshooting the switch before finding this???
timatoe is offline
AC/Heat vs. Vent (( vent dosen't work idk why )) gamer0 YJ Wrangler Technical Forum 10 04-10-2009 11:24 AM
Heat vent problem Cchandler TJ Wrangler Technical Forum 6 01-04-2009 09:35 PM
Air / Heat vent - stuck Axkick TJ Wrangler Technical Forum 4 06-06-2008 10:43 AM
main heat vent not working? joeygeep YJ Wrangler Technical Forum 4 11-27-2004 10:11 AM
Heat and Vent at same time? AWILD YJ Wrangler Technical Forum 1 10-17-2004 04:36 PM
