Headlights ON = Dash Gauges OFF...? - JeepForum.com
post #1 of 19 Old 10-12-2010, 09:11 AM Thread Starter
el scorcho
After "fixing" some 4WD vacuum line stuff, now when I turn on my headlights all the center dash gauges go dead. When I turn the lights off, they all come right back on. Very easily repeatable. It doesn't matter if the Jeep is being driven or if the engine is on or off. It was working fine prior to yesterday evening and the 4WD stuff.
I did nothing with the electrical, not one thing. I'll check some things after work, but if someone has suggestions on where to start, I'd appreciate it.
Thanks
el scorcho is offline
post #2 of 19 Old 10-12-2010, 10:19 AM
jsawduste
2006 YJ Wrangler
Thanks
Explain......No lights, no gauge reading or both ? Center Pod only, correct ? Tach and speedo OK ?
jsawduste is offline
post #3 of 19 Old 10-12-2010, 10:33 AM
Apollo12227
All of my interior lights do the same thing but when I turn the high beams on. Does it every time I turn on the brights, all tge dash lights go out. The gauges still work just not any of the dash lights. Radio keeps working too.
Let me know if you get this figured out as it may solve my delima too.
Apollo12227 is offline
post #4 of 19 Old 10-12-2010, 11:31 AM
jsawduste
2006 YJ Wrangler
Got a couple thoughts. Let me look at my wiring CD. TTYL.
post #5 of 19 Old 10-12-2010, 02:10 PM Thread Starter
el scorcho
Update
Update
I've isolated the problem to the dash dimmer switch. If the dimmer switch is on but rolled all the way down/off then the gauges operate normally. Otherwise, the temp gauge gets higher as I roll the dimmer switch up/brighter until the needle pegs out. But the fuel, oil and battery just look like I turned off the vehicle. The clock just stops. Also, no dash lights come on. This only happens when the key is in the "accessory" or "on" position and the dimmer switch is pressed on BUT not rolled down/adjusted to off.
Thanks
post #6 of 19 Old 10-12-2010, 08:38 PM
jsawduste
2006 YJ Wrangler
Apollo, does moving the dimmer switch have any effect on the dash lights at high beam ?
Update
Thanks
More info to ponder. Just got home from my daughters soccer game. Need to chance to study the wiring.
post #7 of 19 Old 10-12-2010, 09:23 PM
c_coops
I've had the exact same problem for going on two years now and I've tried replacing the dimmer switch with no avail. I think it could be corrosion where the dash wires mate with the plastic plugs.
c_coops is offline
post #8 of 19 Old 10-13-2010, 10:13 AM Thread Starter
el scorcho
Solution!!!
I took apart the dimmer switch and cleaned it; it didn't fix anything, but it's cleaner.
Here's what worked:
I took off the center dash instrument cluster and cleaned the traces. In a few spots where the protective plastic coating had separated, I cleaned the traces with a Q-Tip and some alcohol. Things are back to normal for the time being.
post #9 of 19 Old 10-13-2010, 02:23 PM
Mistic
The only area that I can think of where your headlights and dash lights have any contact is at the head light switch. So I would guess that either the switch is going bad or there is a high bean / low bean switch on the column that may be going bad and back feeding to the man headlight switch.
I would probe the headlight switch with a test light as you alternate between high and low beams and see what you come up with.
Unless you have a relay that toasted itself.
Mistic is offline
post #10 of 19 Old 10-13-2010, 02:37 PM
jsawduste
2006 YJ Wrangler
Good advice.
Again I have not had a chance to look at my wiring CD(s) yet.
I eliminated the dimmer so my set up is a little different. Plus my lights are on relays.
The HL switch has 2 power feeds. One for headlights and the other for dash lights. If the switch is bad then the extra current draw of the HB`s might be breaking contact. Just a guess at this point. Jeep has full current running through the HL switch. Not a very good set up.
The Hi Beam switch has 4 (need to verify) wires.
Both the low beam and the high beam both run through the HB switch. The HB indicator light and the Hi/Low`s are the outputs.
Again, I need to work on this more and may retract a statement. Bad time of the week right now.
post #11 of 19 Old 10-13-2010, 04:14 PM
Apollo12227
All of my interior lights do the same thing but when I turn the high beams on. Does it every time I turn on the brights, all the dash lights go out. The gauges still work just not any of the dash lights. Radio keeps working too.
No, but I have a linked issue where if I leave the dash lights on at night, the switch will heat up and all of the lights, inside, headlights, etc will begin to shut on... off... on off....on.....off.......................on....of.. .. etc. If I turn the dimmers off while driving, the switch never gets hot and does this. If I leave the dash bezzel off and the switch unscrewed from the dash, it wont do it even with the dimmer on.
I have a feeling the highbeams on = inside lights off, has something to do with inside lights on, all lights shut off and on randomly after 5-30 minutes.
post #12 of 19 Old 02-27-2014, 01:58 PM
roadyrob
1987 YJ Wrangler
as I'm having the same problem I figured I'd revive this thread. has anyone found a solution to this? gauges work when head lights are off then peg when headlights are on. can do the same thing by adjusting the dimmer switch. seems like it would be the switch but posters here say changing the switch didn't fix it.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #13 of 19 Old 02-28-2014, 03:04 AM
roadyrob
1987 YJ Wrangler
bump for the morning crowd
roadyrob is offline
post #14 of 19 Old 02-28-2014, 05:19 AM
Mark05059
bad ground on the high beam circuit.. probably the high beam indicator lamp... easiest way to check it is to just remove the lamp and then see what it does
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #15 of 19 Old 02-28-2014, 07:46 AM
Que89YJ
Bad guage ground. Clean your circuit board connector.
http://www.jeepforum.com/forum/f12/r...er-how-991307/
Que89YJ is offline
dash guage , electrical issue , electrical problem , head light
Dash gauges CBinDC YJ Wrangler Technical Forum 11 03-31-2010 05:05 PM
Need New Dash Gauges Mikey1234 YJ Wrangler Technical Forum 5 01-26-2010 06:55 PM
Dash gauges rcanova YJ Wrangler Technical Forum 2 10-22-2009 09:10 AM
dash gauges rficken42 YJ Wrangler Technical Forum 4 04-29-2009 07:31 PM
No gauges or headlights 97MilitaryTJ TJ Wrangler Technical Forum 0 12-04-2007 03:54 AM
