Headlights cause sputtering - Page 2 - JeepForum.com
post #16 of 24 Old 02-13-2012, 09:45 AM
wendell
1987 YJ Wrangler
It's just an old school way to check your alternator. You pull the positive battery cable off the battery while the jeep is running. If the engine dies, the alternator is bad, if the engine stays running, the alternator is good. It's just another easy check you can do to help rule out any problems with the alternator.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #17 of 24 Old 02-13-2012, 09:53 AM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
Mine went through a dying spell some time back. Doing great now, except if I put the headlights on within the first few minutes of engine warm up. Used to be when I turned the radio on, but now it favors the headlights. I pay it no mind any more. I just wait a second and it fires again.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #18 of 24 Old 02-13-2012, 04:58 PM Thread Starter
Xcon0wn4g3
I drove to the parts store and got a new switch. I plugged it in and let it hang there while I drove back home. Everything went well it wasn't trying to die on me. It seems to happen when I need it most.. I was taking off from a stop light once and it started sputtering, I was in the middle of an intersection just rocking back and forth. It wanted to go but then it didn't.
I will try it later and see what happens. I hope that fixed it.
I'm curious, when you guys turn your lights on is there a slight but noticeable drop in rpm's? Can you hear it idle down a little?
Xcon0wn4g3 is offline
post #19 of 24 Old 02-13-2012, 06:15 PM
hotelconucc93
2010 YJ Wrangler
It acts like water in the gas if that makes any sense. You can hear it rumble down and idle low, and then die.
post #20 of 24 Old 02-13-2012, 06:44 PM
Peter Nuss
1987 YJ Wrangler
I would not pull battery cables while the vehicle is running. The electrical surge is bad for your computer and any other sensitive electrical devices. The days of doing that safely are long over. Also, back when it was safe to do, you pulled the negative cable, not the positive cable. Most likely it's your light switch, building up resistance, which creats heat. Better to change it before it melts.
Also, your headlight draw alot of amps. So, at idle it will drag down you rpm slightly. But, so will you wiper or A/C etc. especially on a 4 cylinder. I also think you have something in your ignition system that is getting sensitive to a voltage drop, could be a coil or something. I imagine it will fail soon and you'll know for sure what it is then.
Peter Nuss is offline
post #21 of 24 Old 02-13-2012, 09:44 PM
HurricaneRZA
Correct me if I'm wrong, but could OP test if the switch is the issue by essentially bypassing it?
If OP is running his Jeep and pulls back on the indicator stalk to engage the hi-beam headlights and it sputters and dies. Wouldn't he then know it's not the switch (or not JUST the switch)?
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #22 of 24 Old 02-13-2012, 10:04 PM Thread Starter
Xcon0wn4g3
A while back when I hit the hi-beams it just made it worse but that subsided. The new switch seems to have cured the problem. I guess we can call this thread solved, until further notice. I honestly don't see that small amount of corrosion causing that big of a problem.
I appreciate all the advice.
post #23 of 24 Old 02-14-2012, 11:09 AM
Que89YJ
The way to check an alternator and battery is under load. You need to turn on you lights wipers and all the other loads and read the voltages. I think you have a bad battery or alternator.
Que89YJ is online now
post #24 of 24 Old 04-09-2012, 06:51 AM
hotelconucc93
2010 YJ Wrangler
I finally solved mine. No more issues ever now.
Stalls when idle, can save it with a hell of a throttle push?
Mostly after you have a hot car?
Run the COMPLETE diagnostic for fuel pressure. Mine was a fuel pressure regulator leaking back all pressure. Seemed FINE with vac hose on OR off. (Correct diagnostic pressures that is....). All was well until the 30 min return line pinch test, coupled with 0 fuel line pressure when off.
dying , electrical , headlights , lights , sputtering
Yj sputtering josholson89 YJ Wrangler Technical Forum 10 10-24-2011 09:19 PM
yj sputtering.. again! stcarter44 YJ Wrangler Technical Forum 20 06-09-2011 07:45 PM
89 yj sputtering kitty64 YJ Wrangler Technical Forum 3 03-22-2011 07:29 PM
05 LJ sputtering Unlimitedlou TJ Wrangler Technical Forum 7 02-28-2010 11:13 AM
Sputtering bonehead TJ Wrangler Technical Forum 1 03-29-2003 11:38 AM
