Headlight ON then OFF - JeepForum.com
post #1 of 5 Old 10-15-2004, 10:46 AM Thread Starter
JeepDrivr93
JeepDrivr93's Avatar
OK so my buddy and I are roaming around on some flat dirt land that a sub is being built on (its night) and I have my brights on. Well after about 10 mins my lights turn off, then they turn back on, they did this about 6 more times till I turned my brights off and then they stopped. Now this has happened to me once before but my brights werenít on. I am pretty sure my Jeep wasnít made in Canada so it doesnít have that daytime running lights thing. Also my passenger side headlight was out one day going to school. When I got there I opened the hood and giggled the wires that connect to it and it worked, havenít had a prob since. Any suggestions on what it might be? Thanks
Nick
Jeepless...
1998 Cherokee Classic - SOLD
1993 YJ - SOLD :(
JeepDrivr93 is offline
post #2 of 5 Old 10-16-2004, 05:11 PM
Wrangler95CSA
Wrangler95CSA's Avatar
I don't have a resolution for you, but reading your post made me remember that about 8 months ago mine did the same thing. It's happened I think a grand total for 10 times in the past 5 years. Any knowledge by anyone on this matter would be greatly appreciated.
1995 Emerald Green Wrangler YJ 2.5L, AX-5, NP231 SYE, 33" x 12.50" X-terrains, 6" ProComp CSC, 4.88's F&R, K&N Intake, Banks Power Exhaust Manifold & Cat Back, MagnaFlow Cat, AirAid Throttle Body Spacer, Rock-It 60MM Throttle Body, Mean Green Alternator, Reverse Glow Halo Gauges, JKS Quick-Disconnects, Energy Suspension Body Mounts, Warn Rock Crawler Bumpers F&R, Warn Spare Tire Carrier, Warn 9.5ti, Brown Dog Motor Mounts, Flow-Kooler Water Pump
My RigRater Score: 501RRv1.0 with a BOA of 21.30
Wrangler95CSA is offline
post #3 of 5 Old 10-16-2004, 11:04 PM
fratis
fratis's Avatar
try looking at the fusebox, the fuse might not be bad but the actual box can be. mosture can run down there when it rains etc. without knowing. a corrosion buildup can cause intermittent working. i also had/have a problem with the connector on the box side is slightly cracked and sometimes the fuse gets loose. these connection problems can also happen at the switch itself wich i also had.
fratis is offline
post #4 of 5 Old 10-17-2004, 02:26 AM
bigwheels89
2011 WK
When I got my Jeep a couple months ago I had one of the headlights out when on bright.I got a new one and it was out too,I got to looking and the female plug that the bright prong goes into had pushed back in the holder and wasn't making contact.I shoved it back in with a small screwdriver and it's fine now.Don't know if this is your problem but you might take a look.
bigwheels89 is offline
post #5 of 5 Old 10-17-2004, 11:27 AM Thread Starter
JeepDrivr93
alright sweet. thanks for the help, ill be checking out both of thoes ideas. Thanks again
Nick
Jeepless...
1993 YJ - SOLD :(
only one headlight UNCLEBRO TJ Wrangler Technical Forum 13 07-13-2013 09:58 AM
help with headlight bdhawk TJ Wrangler Technical Forum 2 11-10-2009 01:34 PM
Need Serious Headlight Help!! MuddyWrangla YJ Wrangler Technical Forum 4 01-16-2005 12:25 AM
Headlight aim Digitalchaos TJ Wrangler Technical Forum 18 12-29-2002 10:14 PM
Headlight Help jfarrell YJ Wrangler Technical Forum 3 04-06-2002 11:37 AM
