headlight problems..... not the switch.... - JeepForum.com
post #1 of 16 Old 12-23-2013, 09:45 PM Thread Starter
silver03cobra
So my headlights started flickering as I was driving then went out.... I pulled over a hit the center of the grill..boom lights on made it home... next night no lights.. hit the grill got amber and brake lights.. replaced switch, nothing. Grounds by headlights are kinda weak... but good... fuses are good too. Need to solve this!
silver03cobra is offline
post #2 of 16 Old 12-23-2013, 09:46 PM Thread Starter
silver03cobra
No sign of bad wires behind grill....
post #3 of 16 Old 12-23-2013, 09:58 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Use your multimeter and verify you have power at the low beam/high beam wires at the lights themselves. If you do, read this:
http://www.jeepforum.com/forum/f12/h...rence-1399040/
I suggest rewiring them for better lighting and to ensure they work when needed.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #4 of 16 Old 12-23-2013, 10:02 PM Thread Starter
silver03cobra
Test light says no... tomorrow I will put the meter on it... don't it will change
post #5 of 16 Old 12-23-2013, 10:06 PM
Luuca
Luuca's Avatar
SO no power at the bulbs from the factory wires. Trace them back and/or check continuity of the wirse from the end point to the switch.
Hitting the grill and they came back on tells me to look at the wiring at the grill. The wire could look fine, but have a break in it or corrosion from a pin hole.
YJOTM Sept. 2017
Luuca is offline
post #6 of 16 Old 12-23-2013, 11:09 PM
jokerchief462
Check the connectors female pins are making contact and not loose.
The ground is the screw holding the eyelid. Remove screw and eyelid and scratch some paint for the eyelid to ground to reinstall.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #7 of 16 Old 12-24-2013, 02:38 PM Thread Starter
silver03cobra
Grounds are good at light the connectors are good and tight.. no power at conector
post #8 of 16 Old 12-24-2013, 03:16 PM Thread Starter
silver03cobra
What color wire at the light is low beam??? just going to hard wire it for the night
post #9 of 16 Old 12-24-2013, 05:07 PM
mudsweatNgearz
1987 YJ Wrangler
If I were you I would just do the headlight mod. Your problems are over period. Plus you will have much brighter lights.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #10 of 16 Old 12-24-2013, 07:52 PM
Luuca
Luuca's Avatar
Not exactly. The standard headlight mo still uses the hi and low beam wires to activate the relays to the lights. If he has no power to them, the mod won't do him any good. He could rewrite the switch to the relays and that would fix it.
Posted via my pretentious iPhone.
YJOTM Sept. 2017
Luuca is offline
post #11 of 16 Old 12-25-2013, 01:02 PM Thread Starter
silver03cobra
Head light mod?
post #12 of 16 Old 12-25-2013, 01:40 PM
Luuca
Luuca's Avatar
Head light mod?
The link in my first post. How to require and set up your headlights for more reliability and brightness.
YJOTM Sept. 2017
Luuca is offline
post #13 of 16 Old 12-26-2013, 02:52 PM
blake989
Had the same problem my friend. The factory headlight harness runs along the driverside, above the fender well to the bottom center of the grill. At this location, jeep spliced "Y" the wires to run to each headlight. Your splices, like mine, have finally reached their life. It's a pain in the *** to get to, but you need to reach between the radiator and back of the grill, pull down the harness and rebuild the splices.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #14 of 16 Old 12-27-2013, 12:20 AM Thread Starter
silver03cobra
Wouldn't drivers light turn on???,
post #15 of 16 Old 12-27-2013, 12:24 AM Thread Starter
silver03cobra
Power comes from fuse to switch to driver side then pass... so the Y would allow one light right??
