Headlight problem during rain - JeepForum.com
post #1 of 6 Old 08-24-2013, 05:54 AM Thread Starter
Rufe
Recently my headlights have started going on and off while driving in the rain. They work properly when I am stopped or when it is not raining. How do I begin to find the problem when they are working when I am checking them out? Where do I start when there are no obvious loose wires or connections?
I would welcome any suggestions.
Rufus
Rufe is offline
post #2 of 6 Old 08-24-2013, 08:00 AM
jokerchief462
The switch is heating up and protecting itself like it was designed. For some reason only in the rain though.
You can replace the switch easy enough and or do the headlight relay mod.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 6 Old 08-24-2013, 09:36 AM
Que89YJ
It's the switch itself. You can pull it out and try and clean it or replace it.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #4 of 6 Old 08-24-2013, 10:16 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Here's a thread that discusses that and new replacement switches: http://www.jeepforum.com/forum/f12/h...eaning-865127/
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #5 of 6 Old 08-24-2013, 10:35 AM
warthog312
If you own a YJ, you need to own a multimeter. Exactly for things like this. Is more than likely your switch, but if there's a short somewhere causing the whole problem, you'll need a meter to chase it down. Even the really nice models aren't too expensive, I recommend picking one up, it'll pay for itself in saved headaches in no time. Good luck!
Click for build thread:
- 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline
post #6 of 6 Old 08-24-2013, 07:14 PM Thread Starter
Rufe
Thanks for the info and link. I think I will replace the light switch. Cheap enough fix if it is the source of problem. I have a multimeter but since the problem only occurs when running on road in rain it is hard to use the meter to check problem.
I will be happy to spend the money for a new switch on the chance it will work.
Thanks again,
Rufe
Rufe is offline
