#1 | |
Headlight options- upgrade
Any opinions on the Hella vision plus lamps? I see a few options at quadratec.
Hellla, IPF, Delta I just can't make up my mind. Please sheld some light ![]()
#2 |
I have the Hella lamps with PIAA bulbs and I love the way they look.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride 1991 YJ Sahara 4.0L Automatic 1978 Dodge Lil Red Express - work in progress |
#3 |
I put some Sylvania halogen Xtra Visions in my explorer to replace the PIAA's that the last owner had put in. They worked great but both burned out in less that a year, so I put back the dimmer PIAA's but they still work at least.
1999 TJ, 4.0, AX15 5-Speed, NP231, Dana 30 open 3.73, Dana 35 Detroit Locker 3.73, Rough Country 2.5" suspension lift, 1.25" body lift, 2.2 shocks/stabilizer, JKS Discos, 33 x 12.50 Mickey Thompson MTZ tires on 15 x 8.5 MT Classics |
#4 |
I've used the Hella Visions in the past. I don't think they were near as good as the IPF's with Silverstar 9003 Bulbs I am using now
I bought the IPF's Here http://www.ok4wd.com/index.php/catalog/product/ipf_h4_conversion_lense_rectangular/
Deaver Don't talk much but listen like hell |
#5 | |
#6 |
Deaver,
Does your IPF's have cuts in the lens or is it flat glass? Searching around a bit, I read that IPF changed lights at some point. I think but not sure the ones with the cut lens are the better ones. The link you provided was hard to tell the lens style. http://www.quadratec.com/Assets/Photos/p18087c.jpg I guess I'll call around tomorrow to see if that is the actual photo. Those look more like e-code. Thanks |
#7 |
The IPF's that I have are indeed E-Codes. The lens have a "fluted" glass. They are the ones currently available
IPF did experiment with a different lens configuration a while back and have since returned to their original design Although they are E-Codes, I've never had a problem with PA State inspection. Hella does offer an E-Code version, but not easy to come by. The Hella Visions are NOT E-Codes. I have tried other brands and configurations in my vehicles over the years, I wouldn't use anything else. I think the DOT standard for lighting is horrible by comparison to the European Standard (E-Code) E-Codes offer a much better pattern and are much,much more effective and safer, especially in inclement weather
#8 |
Thanks for the good info!
#9 | |
#10 | |
[color=#996600]/l[/color][color=#000000] , [/color][color=#996600] [[/color][color=#000000]____[/color][color=#996600]][/color], [color=#996600]l---L--[color=#CCCCCC][][/color][color=#996600]lllllll[/color][color=#CCCCCC][][/color]-[/color] [color=#000000][b]()_) ()_)[/b]----[b])_)[/b] [/color][Url=http://www.deepblueforum.com]Deep Blue Forum[/url] Member #1 of the "I Hate Torx Club!" ~anyone with a Jeep is an automatic member, and anyone can be member #1~ |
#11 |
[I'm That Good]
I went with the Delta conversion kit from Quadratec with Sylvania Silverstar bulbs and like it much better than the OEM headlights.
Pimptiva.com |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
