Headlight Help/ 91 YJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Headlight Help/ 91 YJ
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-04-2015, 06:17 AM   #1
Latefreight727
Headlights stopped working. The blinkers are dead as well. The running lights work but that's it. Any ideas. I didn't see a fuse for headlamps in the fuse box. Headlights are somewhat important.
Latefreight727 is offline   Reply With Quote Quick reply to this message
Unread 08-04-2015, 08:15 AM   #2
Que89YJ
Did you check the fuses under the hood in the PDC?
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 08-04-2015, 12:01 PM   #3
Latefreight727
nope. Will check when i get home.
Unread 08-05-2015, 06:18 AM   #4
Latefreight727
The fuse is good. What else could cause the head lights and the blinkers to not work. could the multifunction switch (blinker, bright, wiper) in the column cause that? If so how hard is that to change?
Unread 08-05-2015, 01:11 PM   #5
Que89YJ
Has the wiring been modified? Did they both stop at the same time? Do your other lights work(High beams, hazards, brakes etc)?
Unread 08-05-2015, 06:24 PM   #6
Latefreight727
Yes, they stopped at the same time. The running lights work but no blinkers, headlights or brights.
Unread 08-05-2015, 07:56 PM   #7
IA93Javert
IA93Javert's Avatar
Have you run a tester on everything under the dash to make sure you have current going all the way out to the headlights?
You can fix stupid....it's just a felony.
[B]93 Olympic edition rebuild[/B]
[URL]http://www.jeepforum.com/forum/f22/93-iowa-yj-multi-stage-restore-2715858/[/URL]
IA93Javert is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 06:23 AM   #8
Latefreight727
I have not tested it yet. I will get the multi-meter out today. The multifunction switch feels like its jacked up. I was wondering how to get to it. Do I just have to pull the steering wheel?
Unread 08-06-2015, 07:47 AM   #9
Que89YJ
You need to break out the meter and check power into the light switch and the dimmer. Follow it back.
Unread 08-06-2015, 08:00 AM   #10
jbolty
jbolty's Avatar
the dimmer switch is not under the wheel, it's operated by a rod connected to the switch and is located low down on the column. It's not uncommon for the switch to be bad, loose, kicked or the rod out of place.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 10:01 AM   #11
Latefreight727
Ok, I have power to the head light harness at the bulb. At the bulb there are 3 wires. A ground, white and red, and green. The green has 13.3 volts and the white and red has .3 volts with the brights off and .2 volts with the brights on. Would the regular low beam lamps not work if the high beam switch s bad. It definitely feels like the high beam switch is bad. It's really hard to cycle it on and off. That doesn't explain the turn signals not working. I will go see if I have power to the turn signals now.
Unread 08-13-2015, 10:12 AM   #12
Que89YJ
Are your hazards dead too?
Unread 08-13-2015, 12:26 PM   #13
Latefreight727
Nope, the hazards still work. Just the head lights and the blinkers are not working.
Unread 08-13-2015, 12:40 PM   #14
Drednot
Drednot's Avatar
my 91 has a dog hair funky buildup on everything under the dash. My dimmer switch is gunked up to where the brites will flash, but not click to stay on. The headlights, turn signals, and ignition switch are all down there on the lower column and are starting to cause grief after twenty plus years. And, the plastic turn signal switch in the column has reached beyond its design life expectancy. The more you yank on it to get the high beams to work, the more broken it feels. My hazard switch was missing which was part of the turn signal switch.
I started looking into why my hazards didn't work, and I started finding all this other stuff to where the column will come out to do a full overhaul just to make it nice. there are so many electrical components under there that can cause mayhem, its a good idea to go through everything. That's my plan at least.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 12:43 PM   #15
Drednot
Drednot's Avatar
Did you try scraping the grounds on both side of the grille?
"Non Vi Sed, Arte"
