Headlight dim - JeepForum.com
post #1 of 5 Old 05-07-2010, 07:50 PM Thread Starter
gryph
1987 YJ Wrangler
Headlight dim
I just replaced my headlights because the passenger side high beam wasn't working. I replaced them with Rampage H4
Now the passenger side highbeam still isn't working, but tonight the low beam was dim.........
Any ideas?
1987 Wrangler YJ, 2010 328xi Msport, 2005 Range Rover HSE Grey/Grey,
1990 C2 964 Cabrio triple Black, 1987 Corvette
gryph is offline
post #2 of 5 Old 05-07-2010, 08:04 PM
gunshw301
I did the delta h4 conversion. Mine did the same thing shortly after I did the swap. My drivers side lamp was not bright and then the Highs would not light up. I was mad that they sent me bad bulbs. I did not do anything for a couple days and then everything worked. Cant explain it.
gunshw301 is offline
post #3 of 5 Old 05-07-2010, 08:07 PM
Burnerman
Burnerman's Avatar
Clean the plug for the headlights. Get all of the old dielectric grease out and clean them out good with electrical contact cleaner. Scrape any corrosion from the contacts and apply new dielectric grease. See if that works.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #4 of 5 Old 05-07-2010, 11:28 PM
MJMPC
Check your headlight ground wires clean and tighten.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 5 Old 05-08-2010, 11:59 AM
havasu
On permanent vacation
havasu's Avatar
^^I'd also recommend this^^
havasu is offline
help with headlight bdhawk TJ Wrangler Technical Forum 2 11-10-2009 01:34 PM
Headlight out on 99 tj nopa TJ Wrangler Technical Forum 7 03-10-2009 06:28 PM
Headlight kit libertynewyork TJ Wrangler Technical Forum 32 10-20-2007 09:09 PM
Need Serious Headlight Help!! MuddyWrangla YJ Wrangler Technical Forum 4 01-16-2005 12:25 AM
Headlight ON then OFF JeepDrivr93 YJ Wrangler Technical Forum 4 10-17-2004 11:27 AM
