Headlight adjustment screws - JeepForum.com
post #1 of 3 Old 02-15-2008, 10:40 AM Thread Starter
durangoyj
One of mine headlights has both adjustment screw plastic thingys broke. After several trips to Autozone and Checker I still haven't found the right size one, even though they are labeled for jeep. Any suggestions? The dealer wants $15 for two new ones. I've thought about just getting a long bolt and a couple of nuts and washers and fabbing something, anyone done that before?
Colorado Jeep Club Member # 176
\m/(..)\m/ "Rock on!"
durangoyj is offline
post #2 of 3 Old 02-15-2008, 11:13 AM
Jeebs
2015 JK Wrangler
I had the same problem. I just went and got some long, skinny bolts (I can get the sizes when I get home) and some washers. It works out the exact same. The hardest part was getting the stupid plastic part and the bolt off (the plastic part had been pushed through). Spent a whopping $1 on it at Home Depot.
Jeebs is offline
post #3 of 3 Old 02-15-2008, 11:28 AM Thread Starter
durangoyj
I'll probably go that route, glad to hear it works. Thanks for the reply.
headlight adjustment screws stripped...am i screwed? kswyg001 TJ Wrangler Technical Forum 6 02-12-2010 03:51 PM
Headlight adjustment ... which screws? liquids JK Wrangler Technical Forum 4 11-14-2007 04:35 PM
Fuel mixture adjustment screws 89_Sahara YJ Wrangler Technical Forum 1 03-25-2006 10:50 PM
Headlight Adjustment Screws MCanavan TJ Wrangler Technical Forum 6 03-19-2006 10:23 AM
headlight screws Dr Gutiemouth TJ Wrangler Technical Forum 4 09-29-2004 08:15 PM
