Headlamp adjusting screw - JeepForum.com
post #1 of 3 Old 02-11-2013, 08:25 PM Thread Starter
johnridesjeeps
So I don't drive much at night, but when I do I can't see much because my headlights point practically straight down. When doing the adjustments I noticed my passenger side light doesn't have the retaining nut on the back side so I can't adjust up and down. Ive tried finding a replacement online with no luck. Any help or clues? Thanks. This is for my 93 yj. I've found the screws and nuts for a zj and a xj. But no yj luck.
johnridesjeeps is offline
post #2 of 3 Old 02-11-2013, 08:48 PM
jokerchief462
http://www.4x4groupbuy.com/store/cro...w-p-57962.html
Screws but no other hardware so stealership may be the only option other than the JY. Attached is the parts drawing look at #14 shows the screw and the nut or assembly the crew uses to hold onto the body and move the light in the can.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 3 Old 02-11-2013, 09:17 PM Thread Starter
johnridesjeeps
Thanks for the response. So part 14 has the screw and that block. But looking at the jeep, the screw and block go inside the lamp assembly housing. I need the retaining piece, a flat stupid metal piece that goes behind the grill the holds the bolt. I'm at a loss. May have to suck it up and go to the stealership.
