Head lights - JeepForum.com
post #1 of 8 Old 02-18-2013, 02:57 PM Thread Starter
Dluenz
Head lights
I'd like some better headlights. Not blue but very white or a hint of blue. Is that possible for YJs?
1998 ZJ Limited 5.9
Dluenz is offline
post #2 of 8 Old 02-18-2013, 03:29 PM
NHfireLJ
NHfireLJ's Avatar
Delta D4 kits...
best bet...
http://www.quadratec.com/products/97009_121.htm
and do this too
http://www.jeepforum.com/forum/f12/h...rence-1399040/
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #3 of 8 Old 02-18-2013, 04:51 PM
Labhound
If the Delta D4 kit has everything, so it says, why do the relay setup?
Labhound is offline
post #4 of 8 Old 02-18-2013, 05:08 PM
Mark05059
more power to the lights which makes them even brighter
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 02-18-2013, 05:23 PM
Mywrangler94
Why not try the relay mod first. I did it and have no need to spend any other money on lights. I spent it elsewhere. To be perfectly frank, if your going to upgrade the lights be sure you aim them PROPERLY. Have a little consideration and not blind everyone else on the road. I have a 4" lift and aimed them after I installed it. Just a little consideration for every other driver......
Mywrangler94 is offline
post #6 of 8 Old 02-18-2013, 05:30 PM
sardog211
AMEN.... Adjusting after you so a lift is not only needed but respectful to those that you are behind and oncoming traffic.
sardog211 is offline
post #7 of 8 Old 02-18-2013, 06:46 PM
NHfireLJ
NHfireLJ's Avatar
Because the factory wiring is old and really under sized for the amperage of after market lights... Even with factory lamps, you get an improvemnt with the relay set up... Try it an be a believer grasshopper
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #8 of 8 Old 02-18-2013, 07:03 PM
pasinbuy
NHfire, this is a remarkable write up. http://www.jeepforum.com/forum/f12/h...rence-1399040/
Thanks for forwarding this upgrade.
pasinbuy is offline
