head lights - JeepForum.com
post #1 of 7 Old 08-10-2011, 09:33 AM Thread Starter
MFKNZACK
head lights
my head lights turn on and off sometimes? ive seen it do it on a few.... whats the fix i know yall know! lol
MFKNZACK is offline
post #2 of 7 Old 08-10-2011, 10:11 AM
grandboost98
when i first got my jeep the lights would go out over a bump and then come back on after the next bump. i never intentionally fixed it but it hasnt done that since i took my dash apart to clean up some connections. im guessing it was probably a bad ground
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 7 Old 08-10-2011, 10:22 AM
92 Green YJ
92 Green YJ's Avatar
When mine did that it turned out to be dust in the headlight switch. I pu,led the witch and took it apart for a good cleaning. Fixed the issue
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #4 of 7 Old 08-10-2011, 12:46 PM
Xpress
Lots of things could be at play here, but first start with your connections on the back of the headlights. Make sure they are clean as a whistle- including the contacts inside of the plug itself. Any sort of corrosion or rust can make a bad connection and give intermittent power.
Also double check the crimped connections on the plug too, if one is frayed then it can cause an intermittent connection. Put some die-electrical grease on the contacts to seal them up from the elements.
All about that unibody life.
Xpress is offline
post #5 of 7 Old 08-10-2011, 03:23 PM
Jarred2
its most likely a dusty connector of some sort. mine did it to me too and i took the whole dash apart and field day'd it. never had an issue since. probably a good idea to do anyways.
Jarred2 is offline
post #6 of 7 Old 08-10-2011, 03:40 PM
steelman10
Take your bulbs out of every socket. headlights, tailights, blinkers, ect. And apply dialectric grease it will save you . Not only in elecrical problems but your bulbs will last longer.
steelman10 is offline
post #7 of 7 Old 08-10-2011, 07:40 PM
matterbuilt23
if you wheel your jeep alot, its not a bad idea to go around checking all your grounding wires, and giving them a good crank or two to make sure your not "wiggiling" your wires loose. Also never hurts to clean all your connections on a slow rainy day in the shop. Regular maintinence on the small stupid stuff surprisingly pays off!
matterbuilt23 is offline
My running lights would work but the head lights come on im at a loss at this JeepLock YJ Wrangler Technical Forum 2 01-11-2011 09:16 PM
Head lights always on.... MikeyJ TJ Wrangler Technical Forum 8 11-16-2010 08:45 PM
Head Lights work, but not tail lights JpBill YJ Wrangler Technical Forum 6 08-25-2008 08:51 AM
Head lights on, with everything off oldyeller TJ Wrangler Technical Forum 2 08-30-2006 07:20 AM
Head lights JWBlink9 YJ Wrangler Technical Forum 6 05-27-2003 02:25 AM
