Head light relay mod write up....WOW what a difference - Page 8 - JeepForum.com
 17Likes
post #106 of 469 Old 09-13-2012, 06:25 PM
HurricaneRZA
Hows the light control w those? I got the autopal e-codes off fleabay and I love em. The output is awesome, but more importantly the lines are crisp. No 'lost light"
The e-codes have better light placement due to the lenses and the cut off. DOT is only really rated on the ability not to melt from bulb heat Europeans are really picky about that so you're better off keeping the Autopals, but upgrading bulbs.
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #107 of 469 Old 09-13-2012, 06:26 PM
kjg26
kjg26's Avatar
Can you link to the ebay lights?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #108 of 469 Old 09-13-2012, 06:29 PM
HurricaneRZA
My kit looked just like this one, if he has Autopal they should be the same...
http://www.ebay.com/itm/87-95-JEEP-W...ht_1876wt_1344
post #109 of 469 Old 09-13-2012, 06:32 PM
kjg26
kjg26's Avatar
Thoughts on these?
http://www.dashzracing.com/87-95-Jee...hts-Black.html
kjg26 is offline
post #110 of 469 Old 09-13-2012, 06:42 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
Not sure by what you mean by light control. Output is great. I have a 2012 Tacoma TRD and the Rampage h4s are every bit as bright as the Taco lights.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #111 of 469 Old 09-13-2012, 06:42 PM
HurricaneRZA
The stamp on the outside lens looks to be the same as the ones I pulled off my Jeep (non-projector). The lens is plastic and they're really not good quality and scatter light
You could give 'em a shot, assuming they accept returns... Personally I went with the common theme on the forum, go Euro code and don't look back
post #112 of 469 Old 09-13-2012, 06:43 PM
kjg26
kjg26's Avatar
HurricaneRza. Is that a response for me?
kjg26 is offline
post #113 of 469 Old 09-13-2012, 06:46 PM
HurricaneRZA
light control is where the light goes, does it scatter or is it aimed. DOT is usually unaimed (newer ones can kinda be aimed), scatters light which is "okay" with halogen bulbs, but complete trash once you drop a HID unit into it...
Euro codes (if you look at the pic) have lenses designed to send most of it onto the street with a slight patch of light upwards to illuminate signs and pedestrians at night...
Check out: http://www.danielsternlighting.com/tech/aim/aim.html
He's forgotten more about it than I've learned
post #114 of 469 Old 09-13-2012, 06:48 PM
HurricaneRZA
Yep, sorry about that... I hit quick reply instead of quote. I had lenses that looked the same minus the projector in the middle. I was REALLY unhappy with the light control
post #115 of 469 Old 09-13-2012, 06:54 PM
AZdEvilYJ
Here's what I got
http://item.mobileweb.ebay.com/viewi...id=97826693701
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #116 of 469 Old 09-13-2012, 07:00 PM
Xpress
The "projector" headlamps you find on eBay are total junk. The light control is very limited, the included bulb is trash, and they are not technically road legal anyways.
DOT Approved DOES NOT indicate a specific way the light is shaped. All the DOT Approved stamp indicates is that the lamp won't kill you or harm you or others in any way when used as directed or intended.
All lenses aim the light, just some do it a lot better than others. Lenses are designed to focus around 95% of the light on the road in front of you, whereas the other 5% is direct upward at road signs off to the right side of the road, as well as straight above for overhead signage.
When you install HID bulbs into a lamp designed for a Halogen bulb, you change the optics completely. HID bulbs create an arch of light around the center of the bulb, whereas Halogen bulbs do not. This arch of light radiates off of the bulb differently than the light coming off of a filament. Ontop of that, the length of the HID bulb is longer than a halogen bulb, so again, the optics are changed (right into a massive flood light that limits your viewing field and blinds oncoming traffic- too bad all of the idiots around here don't realize that, maybe if they spend just a little time researching before they did it then we wouldn't have issues). The light source is radiating differently, and the point of origin is further out from the lens than designed. Try messing with a Maglite and you will understand. Lenses are PRECISELY engineered for the type of bulb that will be shining inside of them. If you find a fluted lens or aimed optical reflector designed for HID bulbs, then it won't be any worse than looking at every other car in oncoming traffic.
Offroad lights are not as affected, as they typically uses a symmetrical fluted lens, or a symmetrical reflector. Those fluted lenses on our headlights (or all of those fancy bends inside of the reflector if you have a clear lens) are what focus the light on the road ahead and create the optical light pattern. That's why they look a bit funky and have all sorts of different patterns on them.
FWIW, I have never credited DSL as being entirely accurate, as his information is relatively outdated.
So, now that we are all up to speed on the technicalities of light sources and types, maybe we can get back on topic
All about that unibody life.
Xpress is offline
post #117 of 469 Old 09-13-2012, 07:00 PM
exige05
I got the delta h4 kit on sale for I wanna say 80 bucks and love them. I'm gonna try this mod this weekend
exige05 is offline
post #118 of 469 Old 09-14-2012, 05:49 AM
Que89YJ
Xpress, good info. Where do the led's fall into the whole bulb thing?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #119 of 469 Old 09-14-2012, 08:13 AM
HurricaneRZA
Check "headlight shootout" thread in jk tech (lol) LEDs would fantastic, and they make great aux lights but the industry seems to be struggling to make an LED headlight to replace stock that is worth the $$$. Right now upgraded H4s or a full HID retrofit are the two big conversions. I was going to go HID but I'm happy with the H4 conversion...
post #120 of 469 Old 09-14-2012, 10:04 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The whole relay aspect of this is great, definite improvement, however one thing was left out of the mod. The stock switch had a thermal system where if there was overdraw, it would drop out and then come back a few seconds later, even it it then dropped out a few seconds after that. The idea is when driving at speed and electrical bad happens, you are likely not in the dark and having to stop and not hit stuff on your own. (Test... drive at 55 in traffic on a curvy road, then close your eyes, then pull over the the shoulder and stop).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
electrical , h4 , head light , headlight upgrade , relay
Looking for Head replacement write up on a 4 cylinder YJ scottballz YJ Wrangler Technical Forum 0 06-29-2011 02:49 PM
Upgraded My Head lights what a difference! Bill_Dunnigan TJ Wrangler Technical Forum 41 03-12-2011 11:20 AM
Difference in fog light wiring make a difference? joeksjeep TJ Wrangler Technical Forum 3 08-13-2010 05:12 PM
Using stock fog light switch to trigger AM light relay vohk TJ Wrangler Technical Forum 3 01-17-2010 12:50 PM
Light Bar Write-up YoungJeep TJ Wrangler Technical Forum 2 03-03-2008 02:56 PM
