Head light relay mod write up....WOW what a difference - Page 5 - JeepForum.com
 21Likes
post #61 of 469 Old 09-09-2012, 08:32 AM
HurricaneRZA
Originally Posted by jimmybob67 View Post
After looking at my wiring (94YJ) It seems adequate for the amperage draw of a 55 watt bulb. Is this mod for an earlier model?
Nope, it even works in TJs too. The keyword is "adequate", which could also be said to be "bare minimum" .
The cap is 55watts, but the 55watt bulb does not get the power as effectively as it should. This relay upgrade helps just give it a but more juice. If you really want to open up the full potential of this modification, you could pick up an E-code H4 conversion and run higher wattage bulbs.
I run the Autopal H4 conversion with what I believe are 80/85watt bulbs. The low beam is just fantastic and I love the cut-off e-code headlamps require that the DOT do not, afterall blinding people is a
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #62 of 469 Old 09-09-2012, 08:48 AM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
The thing you need to remember is that you have two 55 watt bulbs and if it is high beam now it is 2 60 watt. The factory switch is bareley able to handle that kind of current and the length of wire needed to go to the lights begins to see excess resistance hence voltage drop.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #63 of 469 Old 09-09-2012, 10:59 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Which is why your lights are dim and the factory switch burns out causing lights to flicker and shut off when using high and sometimes low. I was driving home in the mud and rain last winter and my lights went out. Scary. Changed the switch soon after and its been fixed. Now I'm going to do this mod to brighten up my headlamps which are already decently bright because they are new.
Michaelgoesrawr is offline
post #64 of 469 Old 09-09-2012, 11:03 AM
HurricaneRZA
That happen to Billy is his YJ too, he took a video of the lights turning off then on then off then on. When the system gets too hot (small wires, long distances and drawing a lot of power like High beams could) they sometimes just shut off until they cool down
post #65 of 469 Old 09-09-2012, 12:49 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
My high beams were doing this exact same thing when I bought it from the PO. I changed out the switch pronto and that fixed it but that is a temp fix in my opinion. Then after some reading on here and other sites I got edumacated!
post #66 of 469 Old 09-09-2012, 04:49 PM
jeff_in_rc
OK everyone I went out Friday night and took my VOM to measure the voltages and here is what I got:
Stock low beams- measured at the headlight connector on the passanger side.
Battery voltage- 12.38 VDC
At the headlight- 11.32 VDC
For a loss of 1.06 VDC
Using a 14g jumper from the battery to the headlight.
battery voltage- 12.55 VDC
At the headlight- 12.32 VDC
For a loss of ONLY 0.23 VDC
I did this just after sunset and had both lights pointed at the garage door and the difference was noticeable.
Well today I went to Autozone to get the parts and they had no idea how to find a relay like the OP used, go figure.
So can anybody pass along a part number for this kind of relay that you cam mount on the firewall etc?
TIA everyone!
Heepo likes this.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
post #67 of 469 Old 09-09-2012, 05:54 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
TIA everyone!
Here ya go. They are all over ebay way cheaper than the auto parts store will ever have them. $7 shipped!..much bigger selection as well. The parts stores will charge you this much likely for one relay and no socket. This listing is for two relays with sockets and free ship.....I bought a set of 5 relays with metal mount tabs and interlocking sockets all for like $12 shipped!!....I love ebay!!
http://www.ebay.com/itm/2PACK-Car-Au...item3cca843f62
These even have the sockets that will connect them to each other (interlocking). I never could find any relay that was factory wired with 12 awg but it is not hard to do so I just did it myself.
post #68 of 469 Old 09-09-2012, 06:00 PM
USMCBuckWild
Hahahah, I just bid on that about 5 minutes ago! Hahaha
USMCBuckWild is offline
post #69 of 469 Old 09-09-2012, 06:07 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
HAHA....my bad, I was thinking that was a BIN. Oh well look around you can prolly find the same deal as a Buy it now.
Here is a better deal..metal mounting tabs. This IS Buy It Now!!!!!. Plus you have spare relays for future modz.
http://www.ebay.com/itm/LOT5-Car-Tru...bd49b0&vxp=mtr
post #70 of 469 Old 09-09-2012, 06:11 PM
Michaelgoesrawr
You can find packs of five with sockets on amazon although they all seem to be cheap, from the reviews anyway. But I guess that's what you get for 7 bucks. A lot of them said that the wiring was wrong, they used 18ga instead of 12/14.
Edit:
http://www.amazon.com/Pack-Relay-Har...s=30+amp+relay
http://www.amazon.com/IMC-Audio-Rela...s=30+amp+relay
http://www.amazon.com/Relay-Harness-...s=30+amp+relay
post #71 of 469 Old 09-09-2012, 06:44 PM
USMCBuckWild
Great, now I feel like an idiot for only buying 2!
Hahaha, oh well, guess I can pick up some more in the future for fog lights and back up lights.
post #72 of 469 Old 09-09-2012, 06:53 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
HAHA....don't feel bad, first relay I bought was a cheapo at the parts store for like $7!!
post #73 of 469 Old 09-09-2012, 10:46 PM
Michaelgoesrawr
Is there such thing as a Double Pole Single Throw relay that used two inputs, the double pole, to activate only one single output instead of one pole for one throw? I've been searching for a while put haven't found anything. My intention is to use a relay for one or two sets of lights each(that part doesn't really matter right now) and to have each relay operated by a single switch except for one master switch that can turn all lights on at the same time if needed(highly unlikely but as of right now it seems like a real good idea) and override the single switch.
Excuse my poor example. Paint and I don't get along well. Lol. I also apologize if this is shouldn't be asked here. I figured it might help someone down the road. OP I will delete it if you like, just shoot me a PM
Edit: I found this
http://www.waytekwire.com/item/75532...L-INPUT-RELAY/
But it's 50 bucks and only 15 amps. What kinda crap is that.
post #74 of 469 Old 09-10-2012, 08:13 AM
jeff_in_rc
Thank you very much mudsweatNgearz, this is exactly what I was looking for.
Now on to a question, why the use of 10g wire? And why not use 14g wire?
Thanks everyone!
post #75 of 469 Old 09-10-2012, 07:47 PM
honda250ex
1987 YJ Wrangler
The headlights aren't producing a yellow out put no more... Nice write up!
It's better to live one day as a lion than a hundred years as a lamb.
http://www.jeepforum.com/forum/f12/honda250exs-buildup-860712/
honda250ex is offline
electrical , h4 , head light , headlight upgrade , relay
Looking for Head replacement write up on a 4 cylinder YJ scottballz YJ Wrangler Technical Forum 0 06-29-2011 02:49 PM
Upgraded My Head lights what a difference! Bill_Dunnigan TJ Wrangler Technical Forum 41 03-12-2011 11:20 AM
Difference in fog light wiring make a difference? joeksjeep TJ Wrangler Technical Forum 3 08-13-2010 05:12 PM
Using stock fog light switch to trigger AM light relay vohk TJ Wrangler Technical Forum 3 01-17-2010 12:50 PM
Light Bar Write-up YoungJeep TJ Wrangler Technical Forum 2 03-03-2008 02:56 PM
