Head light relay mod write up....WOW what a difference - Page 3 - JeepForum.com
 21Likes
post #31 of 469 Old 09-05-2012, 08:32 AM
jeff_in_rc
Very nice, I too will be doing this mod after I use some jumpers for a "test" to see how much better the lights are.
It should be just as drastic as yours, can't wait.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
post #32 of 469 Old 09-05-2012, 12:54 PM
jay-h
jumpers may havr voltage drop of their own.
you could run a 12 ga wire direc to the bul (also be sure the bulb ground is good) . you can also read voltage drop (under load) from hot terminal on battery and from ground side of battery to ground side of bulb. This will show how much power is being lost.
[I posted this reply on a tablet. Sorry about the sucky spelling. Looking at it now, I'm embarassed ]
jay-h is offline
post #33 of 469 Old 09-05-2012, 01:56 PM
jeff_in_rc
Wow, way more info than I was looking for but thanks! I just want to jumper one light at night against my garage door to compare them side by side. I subscribe to the KISS method and I like to see how it will/will not work before jumping into things.
I really like your suggestion of measuring the voltage drop! THANKS!
post #34 of 469 Old 09-06-2012, 09:16 PM
evanjeep
2011 WK
Did you keep the same wires from the switch that dims/bright to the relay and just wire them to the relay? And power come from the battery to the relays to the lights bigger wires= more power to lights? Is that right. Im trying to figure it out lol
evanjeep is offline
post #35 of 469 Old 09-06-2012, 10:47 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Got it right exactly. There is a wire for low and hi beams. Those two go to a relay each which then goes to each light. One relay powers low and one relay power high.
Michaelgoesrawr is offline
post #36 of 469 Old 09-06-2012, 10:51 PM
evanjeep
2011 WK
So use the stock wire from what you dim in the jeep to the relay then from relay 12 gauge to the light same as bright? All is gonna be 12 gauge except for control wires? That's what im trying to figure out
evanjeep is offline
post #37 of 469 Old 09-06-2012, 11:58 PM
Michaelgoesrawr
The stock wires will activate the relays. One will turn on a relay when you turn on the headlights and the other will turn on the relay for the brights when you switch them on in the cab. Yes. It's all 12ga wire. You'll need enough length to go from the battery to the relay, from the relay to the light and ground wires too.
post #38 of 469 Old 09-07-2012, 12:06 AM
evanjeep
2011 WK
That's what i needed to know. Should be a piece of cake then
evanjeep is offline
post #39 of 469 Old 09-07-2012, 12:37 AM
AZdEvilYJ
nice write up!
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #40 of 469 Old 09-07-2012, 04:02 AM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
Yes, I just snipped the headlight wires at the driver side headlight. These wires will control your relays for switching Hi and Low beam.
White wire = Hi beam
Green wire = Lo beam
Black wire = Ground (this wire will no longer be used)
White wire to pin 85 on one relay
Green wire to pin 85 on other relay
ground pin 86 on both relays with same gauge wire
Run 12 gauge wire from batt to pin 30 on both relays. I ran two seperate 12 gauge leads with inline fuses but you could use one lead and splice in a Y just before the relays to feed both relays (you will never use both Hi and Lo at the same time so it won't matter). The only advantage to running two seperate leads is if I lose continuity on one circuit I will still have either hi beam or lo beam to get me home.
Pins 87 will run to the headlights with 12 awg. Be sure to ground the lights with 12 awg also.
Heepo likes this.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #41 of 469 Old 09-07-2012, 04:27 AM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
Originally Posted by TheSmanman View Post
Again, nice job on the conversion. Seems Whitefacegauge.com doesn't exist? Was it a hard mod to do?
http://www.whitegauges.net/products/...ce-Gauges.html
Sorry bout that...it is actually whitefacegauges.net.
The mod was really easy and fun to do! The only place I had a little difficulty was on the tach and speedo. The face lens is held on by a bezel which is a factory crimp so you will need to pry the lip up all the way around the edge of the bezel to get it apart (see step #9 below).
I am VERY happy with the results. I was going to go with led gauge lights but this brightens everything up so much that seeing the gauges is no problem at all.
PS....don't forget to get some orange flourescent needle paint too.!!
post #42 of 469 Old 09-07-2012, 04:55 AM
jimmybob67
Great write up. Thanks. Will be doing this as well.
jimmybob67 is offline
post #43 of 469 Old 09-07-2012, 06:02 AM
TheSmanman
Thanks for the info!
I'm going to order it today. It looks great and when I'm driving around I really can't see my gauges to well, so I'm looking forward to getting the kit.
TheSmanman is offline
post #44 of 469 Old 09-07-2012, 06:25 AM
Kuntryboy816
Kuntryboy816's Avatar
Awesome write up! I was looking into buying some auxillary lighting for driving purposes but I'm definitely trying this out first! Hopefully I'll have time to knock this out this weekend. Will post up some result pics once done.
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #45 of 469 Old 09-07-2012, 07:11 AM
sdotcarter
I called the parts store and they only have one 12v 30 amp relay. Would this be an item radioshack would carry ya think?
sdotcarter is offline
electrical , h4 , head light , headlight upgrade , relay
Looking for Head replacement write up on a 4 cylinder YJ scottballz YJ Wrangler Technical Forum 0 06-29-2011 02:49 PM
Upgraded My Head lights what a difference! Bill_Dunnigan TJ Wrangler Technical Forum 41 03-12-2011 11:20 AM
Difference in fog light wiring make a difference? joeksjeep TJ Wrangler Technical Forum 3 08-13-2010 05:12 PM
Using stock fog light switch to trigger AM light relay vohk TJ Wrangler Technical Forum 3 01-17-2010 12:50 PM
Light Bar Write-up YoungJeep TJ Wrangler Technical Forum 2 03-03-2008 02:56 PM
