Head light relay mod write up....WOW what a difference - Page 2 - JeepForum.com
 13Likes
post #16 of 451 Old 07-30-2012, 05:24 PM
mxmike480
Originally Posted by Mywrangler94 View Post
so you can use that wireing harness to upgrade the headlights on your 88 and my 94 Mike?
Yes it should work on both. Then you can upgrade to headlights that have replaceable bulbs & really throw some light.The sealed beam halogens & the H4s have the same plug,so that makes it an easy mod.
89 Wrangler, 99 Cherokee,(Watch this space for all the mods that I will do to them)
mxmike480 is offline
post #17 of 451 Old 09-02-2012, 05:41 AM
ThomasYJ
This is a lot simpler than I imagined it to be; nice write up.
I already have the ipf h4 conversion and iirc fatboy bulbs, Which throw white and really bright light, so I'm excited to see how they'll be after.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #18 of 451 Old 09-02-2012, 06:19 AM
gunshw301
Just posting for later reference. Nice work.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #19 of 451 Old 09-02-2012, 07:38 AM
HurricaneRZA
What wattage are those bulbs? I did the H4 conversion as a complete noob and didnt take into account bigger bulbs might = bigger wires.
I ended up burning out the socket and damaging the other (hence the relay mod). Its been fantastic ever since, but just something for those with higher watt bulbs to think about if on the stock setup
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #20 of 451 Old 09-03-2012, 02:42 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
Just an update on my relay Mod. Since doing this mod I have went to the Rampage H4 lights and it is an unbelievable improvement!
My relays with the open push-on connectors left some to be desired though. Below is a pic of the original relay mod.
Then I decided to go with the relay socket like in the pic below to tidy things up a bit.
The problem is when I add more mods like additional lighting, electric fan, or what ever else tickles my fancy the mess of relays and fuses will begin to be too cumbersome so I decided to look for options to make things better and more of a factory/professional look so came up with this.
It is a fuse relay panel from a 92 S10 blazer. I completely gutted it, cleaned it up and started from scratch, rewiring it to my custom needs. The relay/fuse box will accomodate up to 6 relays and a dozen or more fuses. It is totally enclosed top and bottom with a hinged lid.
Below is the wired and installed results
I used weatherpack connectors so the whole thing can just be unplugged, removed and modded or serviced as needed
Before
Since my horn was not being used I removed it and used the space to mount the power center.
After
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #21 of 451 Old 09-03-2012, 03:00 PM
jay-h
I did a similar relay conversion (I used separate fuses for high and low beam circuits), and I agree, this is the cheapest, best upgrade in terms of bang for the buck.
To others reading: before you waste money on expensive lights etc, do this (actually since high performance lighting is more sensitive to voltage loss, this should be done first, regardless)
jay-h is offline
post #22 of 451 Old 09-03-2012, 03:08 PM
bad_andy24
Sub
bad_andy24 is offline
post #23 of 451 Old 09-03-2012, 03:12 PM
HurricaneRZA
I'm so glad more Jeepers are doing this instead of HIDs in H4 conversion sockets...
post #24 of 451 Old 09-03-2012, 03:55 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
What a great mod, congratulations, I did this myself before, and I used H4 headlights with Hella headlamps, but I never thought about using a fuse box, that's awesome. I want to follow your example, will start looking for a box. Congratulations again!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is online now
post #25 of 451 Old 09-03-2012, 04:51 PM
ferriolom
This will be done shortly. Also that fusebox may be my pick for my interior fusebox... How hard was it to gut and rewire? Did it use spade connectors underneath to hook in fuses?
ferriolom is offline
post #26 of 451 Old 09-03-2012, 05:43 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
It was easy to gut and rewire. I used all of the existing connectors, i just soldered and used dual wall sealing shrink tube on each splice to attach my new leads onto the existing wires according to what gauge I needed. I had to open up a couple of the terminals and recrimp my new wires to them because there were not enough terminals wired for 12 gauge for my needs.
The terminals were a different style that I had never seen before. They are super heavy duty....much heavier than your average spade connector.
The other benifit is I am going to run a 2 gauge wire to source the box from my battery so I can eliminate all the wires coming off of my battery. In essence it serves as a terminal block/strip as well with built in fuse panel.
post #27 of 451 Old 09-03-2012, 08:29 PM
rage4order
2015 JK Wrangler
Nice! **Subbed for future ref.**
rage4order is offline
post #28 of 451 Old 09-03-2012, 08:31 PM
HanksRide
Nice thread, and I just noticed tonight that I have one headlight out... I will be doing some of this soon..
Subscribed!!
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
HanksRide is offline
post #29 of 451 Old 09-05-2012, 05:31 AM
TheSmanman
Originally Posted by mudsweatNgearz View Post
Whitefacegauge.com. They gave VERY good service. They have a great website with good detailed instructions. Kit was like $25 shipped. I also bought some flourescent orange paint for the needles from a different outfit. The paint is like $8 for a teeny little jar but I had plenty left over. I used a toothpick to apply the paint...worked great. probably the best mod I have done so far as far as bang for the buck.
Again, nice job on the conversion. Seems Whitefacegauge.com doesn't exist? Was it a hard mod to do?
TheSmanman is offline
post #30 of 451 Old 09-05-2012, 08:04 AM
BGarth13
You're my hero! I'll be tackling this project this weekend. Great idea and a very clear and thorough write up... kudos
BGarth13 is offline
electrical , h4 , head light , headlight upgrade , relay
Looking for Head replacement write up on a 4 cylinder YJ scottballz YJ Wrangler Technical Forum 0 06-29-2011 02:49 PM
Upgraded My Head lights what a difference! Bill_Dunnigan TJ Wrangler Technical Forum 41 03-12-2011 11:20 AM
Difference in fog light wiring make a difference? joeksjeep TJ Wrangler Technical Forum 3 08-13-2010 05:12 PM
Using stock fog light switch to trigger AM light relay vohk TJ Wrangler Technical Forum 3 01-17-2010 12:50 PM
Light Bar Write-up YoungJeep TJ Wrangler Technical Forum 2 03-03-2008 02:56 PM
