Head light relay mod write up....WOW what a difference - Page 15 - JeepForum.com
 17Likes
post #211 of 469 Old 11-16-2012, 06:00 PM
TJMike2011
I just finished my relay mod and my pro comp headlamps are now brighter than the 130 watt H3 driving lights. As I began to akin the factory wires, I found them to be 18 ga and replacing with the 12 ga is such a change that it is unbelievable, even reading this thread several times. Thanks again for the write up, and if you are only marginally good at soldering, take your time and it will really pay for your time. Just remember: SOLDER YOUR CONNECTIONS!!!! We are talking headlights here.
Sent from my iPhone5 using JeepForum
TJMike2011 is offline
post #212 of 469 Old 11-17-2012, 03:04 PM
A_Ninja_Racer
I just did this on my brothers ford Taurus it had 9007 bulbs. I ordered new connectors and relays off eBay. I didn't notice any brightness benefits. But he was having issues with blowing bulbs. I'm hoping this fixes it.
A_Ninja_Racer is offline
post #213 of 469 Old 11-19-2012, 10:26 AM
remmons
Has anyone just relayed the stock wires? Any improvment in lighting?
Like not replacing any wires, just adding in the relays before the headlights to take the strain off the switch
Originally Posted by jeff_in_rc View Post
I don't think that it would do anything to help, the loss in voltage comes from the wiring harness from the switch to the headlights. That is what puts the strain on the switch.
The downfall after the switch is the undersized wiring, from my understanding. I don't think it would help.
I had kept my headlight wiring after the relays. I had installed the relays in my headlight circuit near my bulbs. I had used a 12ga feed to my relays and I had used the stock headlight switch and wiring to activate the relays.
And yes, I had seen a significant difference in my light output.
Robert.
remmons is offline
post #214 of 469 Old 11-19-2012, 10:55 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
That's good to know. Maybe you saw a difference because the relays were so close to the headlights and it counter acts voltage drops?
Michaelgoesrawr is offline
post #215 of 469 Old 11-19-2012, 01:11 PM
AZdEvilYJ
I just installed the relays without upgrading the wiring to see what happens, and I had definite lighting difference in the density of the light on the ground and slightly whiter light. Having that said, I will still upgrade the wires in the future for there is still more to be power to be unleashed thanks for the killer write-up.
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is online now
post #216 of 469 Old 11-20-2012, 10:40 AM
remmons
Yes, the relays are only about 6-8" away from the left headlight and are only about 3-1/2 feet from the right headlight.
Robert.
remmons is offline
post #217 of 469 Old 11-27-2012, 09:10 PM
Ciamonkey
i don't know if it is possible but can anyone dumb down this mod a bit for me? Usually when it comes to auto wiring I am freaking useless. I would really like to do this mod but don't quite understand the diagram.
Ciamonkey is offline
post #218 of 469 Old 11-28-2012, 04:34 PM
jeff_in_rc
What is it that you don't understand? It is really straight forward in my book and believe me I am no wiring expert.
If you go back and re-read and look at the wiring drawing I think you will get the picture.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
post #219 of 469 Old 11-28-2012, 05:38 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
What he said.
12v dc is insanely simple. Read, read, read! just sit there and stare at and try to make sense of that diagram at the beginning of the post and bit by bit it will start to make sense. I am self taught in 12v dc and everything I have learned I learned from the internet. You will learn most by doing.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #220 of 469 Old 11-28-2012, 05:43 PM
squishy
Originally Posted by mudsweatNgearz
. You will learn most by doing......
.....Again and again till its right. then all of a sudden you know what you're doing
squishy is offline
post #221 of 469 Old 11-28-2012, 06:20 PM
Ciamonkey
Ok we'll maybe ill give her a shot.
post #222 of 469 Old 11-28-2012, 06:33 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
We are gere to help ya through it......just don't be afraid to ask!!
post #223 of 469 Old 11-28-2012, 07:09 PM
squishy
We are here to help ya through it......just don't be afraid to ask!!
Fixed it.
squishy is offline
post #224 of 469 Old 11-29-2012, 10:41 AM
Ciamonkey
So I just want to clarify that you need to replace from the connector back with 12 gauge wire?
post #225 of 469 Old 11-29-2012, 10:50 AM
Michaelgoesrawr
Best way to do it.
electrical , h4 , head light , headlight upgrade , relay
Looking for Head replacement write up on a 4 cylinder YJ scottballz YJ Wrangler Technical Forum 0 06-29-2011 02:49 PM
Upgraded My Head lights what a difference! Bill_Dunnigan TJ Wrangler Technical Forum 41 03-12-2011 11:20 AM
Difference in fog light wiring make a difference? joeksjeep TJ Wrangler Technical Forum 3 08-13-2010 05:12 PM
Using stock fog light switch to trigger AM light relay vohk TJ Wrangler Technical Forum 3 01-17-2010 12:50 PM
Light Bar Write-up YoungJeep TJ Wrangler Technical Forum 2 03-03-2008 02:56 PM
