head bolt torque spec? - JeepForum.com
post #1 of 4 Old 09-22-2006, 08:11 AM Thread Starter
Jakesteads
for 2.5L motor im getting mixxed info off the net anyone know the torque spec i think the bolt heads are 15mm
Jakesteads is offline
post #2 of 4 Old 09-22-2006, 10:13 AM
crazymon01
crazymon01's Avatar
i suggest goin to parts store and gettin a haines manual for $15 i would look it up in mine but i cant find it.. sorry
4.0
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures??
crazymon01 is offline
post #3 of 4 Old 09-22-2006, 11:42 AM
Semperfi
depends on what year,
1987 and 1988
Bolts 1 thruough 7 and 9, 10............... 85 ft lbs
Bolt 8 only............................................ 75 ft lbs
1989 on
Bolts 1 through 7 and 9, 10................. 110 ft lbs
Bolt 8 only............................................ 100 ft lbs
Semperfi is offline
post #4 of 4 Old 05-16-2010, 07:01 PM
MikeL95YJ
This was old thread which popped up when I created a new one asking about torque spec's on a 95 4cyl head bolt. if anyone's online that can answer this, how are the head bolts numbered/pattern? without a manual or experience with this motor, I'm flying in the dark, but almost done getting this puppy on the road. thanks--mike
MikeL95YJ is offline
Head Bolt Torque for 4.0 Head Swap + other ? nfisher50 YJ Wrangler Technical Forum 15 06-04-2016 09:00 AM
Body Lift Bolt Torque Spec rhbickham TJ Wrangler Technical Forum 6 07-29-2013 05:48 PM
U Bolt Torque Spec dogboy6464 YJ Wrangler Technical Forum 10 07-24-2008 09:30 PM
Banjo Bolt Torque Spec? rgs112 YJ Wrangler Technical Forum 3 07-20-2008 08:13 PM
Idler Pulley Bolt Torque Spec in2jeeps TJ Wrangler Technical Forum 1 09-03-2005 09:51 PM
