head bolt pattern/numbering system on a 4 cyl.? - JeepForum.com
post #1 of 4 Old 05-17-2010, 12:10 PM Thread Starter
MikeL95YJ
I got the torque settings for my '95 2.5 liter head bolts, but need help identifying the #8 bolt. Are they numbered 1-5 on driver's side front to rear, 6-10 passenger side, OR 1-9 odd on driver's side front to rear, 2-10 even on passenger side front to rear, OR vice-versa on any of these, OR some other less logical pattern? thanks--Mike
MikeL95YJ is offline
post #2 of 4 Old 05-17-2010, 01:39 PM
idaholtby
I created this jpeg from info derived from my Chilton's. (That is my disclaimer) but this should be correct for all model year 2.5L Jeep engines...
idaholtby is offline
post #3 of 4 Old 05-17-2010, 02:15 PM Thread Starter
MikeL95YJ
Steve--This is exactly what I needed! My guess did not include the start in the center and spiral clockwise order, but definitely makes it easier to follow the order when torqueing. I'll be adding a Chilton's YJ manual to my collection, as soon as I need another major repair. Thanks for the info--Mike
post #4 of 4 Old 05-17-2010, 02:33 PM
idaholtby
Most all head bolt patterns follow this same pattern so that there is no trapped stress between the bolts. As the bolts are tightened in sequence, the stress is pushed outboard rather than being trapped otherwise. You are fortunate in that you reside in San Diego, as one of our most gifted mods lives in that area. If you ever get stuck and especially need mechanical assistance, then I am sure that Joe Dillard will lend a hand. He commonly offers his assistance to those within his reach. (It may cost you a beer or two, but I suspect he would still help for free) On a side note, the Chilton's is a good reference but falls far short of a factory service manual. It is definitely a good tool to have and if your needs surpass it, you can then get a fsm OR ping the board for help.
YJ Bolt Pattern zeke6785 YJ Wrangler Technical Forum 6 02-12-2011 10:00 AM
stripped torx bolt - cutting notch in bolt head linusb YJ Wrangler Technical Forum 10 05-09-2010 03:55 PM
Bolt pattern jeep couple YJ Wrangler Technical Forum 5 10-20-2007 11:40 AM
Tj bolt pattern BIG KEV TJ Wrangler Technical Forum 5 05-06-2004 07:20 PM
bolt pattern WhiteJeepKid YJ Wrangler Technical Forum 2 11-26-2003 06:28 PM
