Hawaiian Jeep -> California emissions? - JeepForum.com
post #1 of 7 Old 07-31-2002, 06:33 AM Thread Starter
iamthemellowman
My jeep was originally purchased in hawaii... And I was thinking the other day that perhaps the emissions were that of california's...
So what did the 4.0L efi have for calif emissions? Of particular interest is the the throttle body bore diam. would it have a 2.5L one? And if there is a way i can inspect a number somewhere that would tell me if it had calif type emission controls.
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
post #2 of 7 Old 07-31-2002, 10:02 AM
evilpsych
evilpsych's Avatar
look under your jeep.. do you notice a catalytic converter? looks like a smaller muffler inside a cage between the actual muffler and the engine. If you got that. you're fine for CA smog..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 7 Old 07-31-2002, 10:10 AM
RCHavok797
RCHavok797's Avatar
What are you trying to see, if they robbed you of any power or performance gains by using the California emissions standard?
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #4 of 7 Old 07-31-2002, 10:33 AM Thread Starter
iamthemellowman
Well i bought one of those chintzy cone filter and airtube products. And the hose was too large to fit on the TB, so i'm mostly convinced that it was the product i purchased since it seemed like a POS. I was wondering if the 4.0L had different equipment (such as a smaller TB) I don't live in hawaii or california, i'm in Ct. the original owner purchased it in hawaii so i'm trying to determine if it had special-for california emission equipment.
A simpler way to do this: Whats the OD on a 4.0L Throttle body? or ID
p.s. don't buy these products, they overcharge and supply you with the thinnest material... I'm returning mine to make my own.
post #5 of 7 Old 07-31-2002, 10:41 AM
evilpsych
evilpsych's Avatar
for the most part.. there is no "special california equipment" any longer.. virtually all autos nowadays come from the factory with this equipment standard as many other states have implemented similar smog requirements to those of california.
A
post #6 of 7 Old 07-31-2002, 02:43 PM
gojurick
gojurick's Avatar
Look under the hood for the emissions sticker. It'll say if it was built to California standards or US standards.
'92 YJ, SOA w/ 35x12.5 X-terrains,RE quick-discs, Warn HS9500i, Detroit Electrac rear, ARB front, 4xDoctor rocker guards, AGR Steering, Borla Header & exhaust, Atlas II
Many bloody knuckles, Best of all, my wife luvs it too!!!
***Coming soon*** Chevy 350 V8 swap
gojurick is offline
post #7 of 7 Old 07-31-2002, 03:02 PM
RCHavok797
RCHavok797's Avatar
I think the 4.0L throttle body has a larger diameter than the one for the 2.5L.
Change California emissions to High Altitude? keithwdsc TJ Wrangler Technical Forum 4 10-11-2009 05:23 PM
New muffler & emissions in California? bjjfoshizzy TJ Wrangler Technical Forum 13 08-24-2009 03:07 PM
non-california cat in cali-emissions jeep? thesherm TJ Wrangler Technical Forum 11 05-02-2007 05:47 PM
Canadien TJ = California Emissions? NoseriderTJ TJ Wrangler Technical Forum 3 01-13-2004 11:51 PM
Beating California emissions puckeater1 YJ Wrangler Technical Forum 8 05-19-2002 08:15 PM
