Quantcast having trouble removing bumperettes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > having trouble removing bumperettes
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 06-30-2004, 11:44 PM   #1
94jpwrangler
i just bought a rock crawler tire carrier and bumper..(it's being shipped) i have to remove the 2 bumperettes first.. there are 4 bolts holding each one on..two bolts mounted vertically..side by side.. i can get to the 2 on the outside but how do i get to the two on the inside because you have to hold a wrench on the back side while loosening the bolt on the front..take a look at your yj if you have bumperettes.. e-mail globemtg33@cox.net or just post answers... thanks.. max
1994 4.0 5spd wrangler
4" lift 33x12.50" mastercraft m/t
"big reddy"
94jpwrangler is offline   Reply With Quote
Old 07-01-2004, 12:03 AM   #2
ol'abner
Just took mine off. What i did was hose the bolts down with a helathy dose of PB Blaster (God's gift to Jeepaholics). Then I cut the hoops of the bumperettes off with a sawzall (think I spelled that right). Then, I put a wrench behind the bumper to hold the nut, and had a friend crawl under the jeep and hold the wrench. Then, I used an impact wrench to get the bolt off. If you don't have an impact wrench, you can use a socket with any kind of "cheater bar" for leverage. If you don't have a friend, sucks to be you.
AB
ol'abner is offline   Reply With Quote
Old 07-01-2004, 10:33 AM   #3
jagger
I just cut the bolts off with an angle grinder with a nice thin cutting blade, and then the bolts jusrt fall out!
jagger is offline   Reply With Quote
Old 07-01-2004, 12:13 PM   #4
DevilDogJeep
Don't cut them. If you really want to get to them easier just remove the fuel tank guard. Or just fish an 11/16" wrench behind your bumper and you can work it so that it will catch on one of the nuts ( You won't be using your hands just a few fingers). It hurts your hands a little bit but it will save your bumperettes. So if you ever want to bring your Jeep back to stock you don't have to buy new ones. I just took mine off and it took a whole bunch of patience.
/I,[_____],
L---L--[]IIIIIII[]
()_)()_)--------)_)
92 Wrangler
2.5L No mods yet! Besides 31's.
87 Wrangler W/258 stock and even missing parts.
DevilDogJeep is offline   Reply With Quote
Glock Forum
