having problem to find a transmission for yj - JeepForum.com
post #1 of 8 Old 07-05-2013, 01:59 PM Thread Starter
matteyj
hello everyone i got a question , i have a yj 1991 , 4.0 4x4 .. il6 . im having problem with the manual transmission ( 5 speed) ... does anyone knows if i can use another jeep like cherockee or a different transmission instead? since when u talk about wrangler the price changes a lot .... thanks very much ....
stay on 4x4 ..
matteyj is offline
post #2 of 8 Old 07-05-2013, 02:14 PM
Siva283
You can use a cherkar ax15 trans.
Ask me how I know...
Siva283 is offline
post #3 of 8 Old 07-05-2013, 02:44 PM
imstillatwork
You will need to re-drill the t-case mounting holes if you use a Cherokee transmission. Same transmission as the wrangler ax-15, but holes are in a different position. I think 10* off.
imstillatwork is offline
post #4 of 8 Old 07-05-2013, 02:52 PM Thread Starter
matteyj
Im sorry one more question ,,, matters of the 4x4 part? cause i can find on the junk yard transmission but if i got 4x4 is 4c and if i got 6cil is a 4x2 .... makes a difference about the 4x2 or 4x4 ?
matteyj is offline
post #5 of 8 Old 07-05-2013, 03:07 PM
scramblered
Not sure on the Cherokee but I am of the understanding that the output shaft on the Wrangler AX15 with a 4 cyl has 21 splines while the 6 cyl came with 23. Good luck, Dave
"Not all who wander are lost."
scramblered is offline
post #6 of 8 Old 07-05-2013, 03:34 PM
RockWoRM
RockWoRM's Avatar
You can also use the NV3550 5sp from later model TJ's and Libertys, but I would guess there would also be some minor modifications, that I'm not completely up on... but it is do-able.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #7 of 8 Old 07-05-2013, 05:25 PM
Mark05059
You need a 6cyl 4x4 transmission
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 8 Old 07-05-2013, 07:36 PM
Mywrangler94
I know the transfer case off a cherokee is clocked differently, so you have widen the hole in the skid plate/cross member of the YJ. I know, I did it.....Thats all I know guys...
Mywrangler94 is offline
