-   -   having problem to find a transmission for yj (http://www.jeepforum.com/forum/f12/having-problem-find-transmission-yj-1545315/)
matteyj 07-05-2013 01:59 PM
hello everyone i got a question , i have a yj 1991 , 4.0 4x4 .. il6 . im having problem with the manual transmission ( 5 speed) ... does anyone knows if i can use another jeep like cherockee or a different transmission instead? since when u talk about wrangler the price changes a lot .... thanks very much ....
stay on 4x4 ..:2thumbsup:
Siva283 07-05-2013 02:14 PM
You can use a cherkar ax15 trans.
imstillatwork 07-05-2013 02:44 PM
You will need to re-drill the t-case mounting holes if you use a Cherokee transmission. Same transmission as the wrangler ax-15, but holes are in a different position. I think 10* off.
matteyj 07-05-2013 02:52 PM
Im sorry one more question ,,, matters of the 4x4 part? cause i can find on the junk yard transmission but if i got 4x4 is 4c and if i got 6cil is a 4x2 .... makes a difference about the 4x2 or 4x4 ?
scramblered 07-05-2013 03:07 PM
Not sure on the Cherokee but I am of the understanding that the output shaft on the Wrangler AX15 with a 4 cyl has 21 splines while the 6 cyl came with 23. Good luck, Dave
RockWoRM 07-05-2013 03:34 PM
You can also use the NV3550 5sp from later model TJ's and Libertys, but I would guess there would also be some minor modifications, that I'm not completely up on... but it is do-able.
WRM
Mark05059 07-05-2013 05:25 PM
You need a 6cyl 4x4 transmission
Mywrangler94 07-05-2013 07:36 PM
I know the transfer case off a cherokee is clocked differently, so you have widen the hole in the skid plate/cross member of the YJ. I know, I did it.....Thats all I know guys...
The time now is 05:43 PM.
