Having issues with my YJ - Page 2 - JeepForum.com
post #16 of 25 Old 04-22-2013, 08:30 AM Thread Starter
Idawg67
1992 TJ Wrangler
Originally Posted by Snakebite22 View Post
It's a bad computer bro same happened to me you can try replacing the caps or just get a new one
what are the prices for the computers???
Originally Posted by Que89YJ View Post
With a no start you always check fuel at the fuel rail schrader valve and for spark at the plugs first.
I am going to check the valve today... I have until Sat night to get it running
Idawg67 is offline
post #17 of 25 Old 04-22-2013, 08:43 AM
Que89YJ
Check for fuel and spark. As long as you are getting the CEL it is just a matter of isolating down the system that is giving you the problem.
Que89YJ is offline
post #18 of 25 Old 04-25-2013, 07:52 PM Thread Starter
Idawg67
1992 TJ Wrangler
I will be continuing work on this problem over the next few days.. I like to thank everyone for all your help so far I had to take a few days off of working on the jeep due to other issues (mostly weather)..
Idawg67 is offline
post #19 of 25 Old 04-27-2013, 03:50 PM Thread Starter
Idawg67
1992 TJ Wrangler
Okay, we got it running for about 5 minutes, and then it started running rough and died... Now it wont start.. No spark now... Could it be a coil going bad, opening up when it gets warm?? That is the ONLY thing that I can think of... We are now shaking our heads, stumped.
Idawg67 is offline
post #20 of 25 Old 04-27-2013, 05:26 PM Thread Starter
Idawg67
1992 TJ Wrangler
Went back out, took the plug off the front side of the coil pack (accel aftermarket) and tried to start it.. It tried to fire it off, but could not. Tells me it is a bad coil pack...
What you think??
Idawg67 is offline
post #21 of 25 Old 04-27-2013, 09:10 PM
Que89YJ
sounds like it to me
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #22 of 25 Old 04-28-2013, 12:29 PM Thread Starter
Idawg67
1992 TJ Wrangler
I went outside this morning to work on it, turned the key, it fired right up, idled for 20 minutes, shut it off, let it set, turned the key and it fired right off AGAIN... Has not died yet... I wont trust it though until I figure out what the problem is...
Still going to replace the coil LOL
Idawg67 is offline
post #23 of 25 Old 04-28-2013, 02:01 PM
Que89YJ
keep us updated.
Fault codes:
No Start:
Que89YJ is offline
post #24 of 25 Old 04-28-2013, 02:41 PM Thread Starter
Idawg67
1992 TJ Wrangler
I drove it around town (SMALL town) this afternoon... Something is off slightly, so I will prolly replace the coil, the harness going INTO the coil and give it a tune up and see if that helps any...
Idawg67 is offline
post #25 of 25 Old 05-01-2013, 02:15 PM Thread Starter
Idawg67
1992 TJ Wrangler
Okay, it runs fine for a while... I can drive it around town for a while, and then park it, get back into it an hour or two later and it starts, and runs for a while, then it starts losing power.. But it will start back up immediatelly... Is this MAYBE a lose ground or something?? I am PUZZLED now...
Idawg67 is offline
