Having issues with my YJ - JeepForum.com
post #1 of 25 Old 04-17-2013, 05:53 PM Thread Starter
Idawg67
1992 TJ Wrangler
I have a 1992 Wrangler Renegade right now...
Ran, lost ALL power, immediately restarted the other day... Parked it, and went and fired it off to take a look inside and it ran for 30 seconds, went rough running for about 5 seconds, now it wont start at all..
I did the on/off/on/off/on with the key, and the only code I got from the computer was 5 5, which means no computer issues, right??
Idawg67 is offline
post #2 of 25 Old 04-17-2013, 06:33 PM
pete1991YJ
55 means there are no more codes. To find out if the computer is OK just turn the key on and watch the light. It should ome on a few secs and then go out.
First thing I would do is check for spark. Then check for fuel pressure. Whatever it is, does not seem to set an error code - those are usually fuel system probs.
BTW Welcome to JeepForum, you've just found one of the best jeep sites anywhere!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #3 of 25 Old 04-18-2013, 07:52 PM
Squirrel442
I had the same symptoms turned out to be the Crankshaft Position Sensor (CKS), but could be Camshaft Position Sensor (CPS) and may be the Computer (ECU). Could also be a bad engine ground.
Most common cause for what you described is CKS failure. After mine went I threw a code for TPS (Throttle Position Sensor) and had to replace that. Also found a bad ground.
There is a way to test the sensors. First thing you need to do is pull a plug wire and check for a strong spark. If no spark at the plug then check for spark at the coil. if no spark at the coil test the CKS. If you have spark at the coil but not the plugs test the CPS. Check for good grounds hopefully it is a common sensor failure not a computer problem.
Engine needs spark, fuel, oxygen. If you have spark check to see why you don't have fuel. if you have all three and it won't start then check the timing.
Edit - Wanted to add that when my CKS went out I did not throw a code. Bad ground, also no code.
I've been there ... remember it is a hobby
Lots of info on the site
Squirrel442 is offline
post #4 of 25 Old 04-18-2013, 09:10 PM
Jim93YJ
Jim93YJ's Avatar
I lost all power immediately when I had my 2.5L. Ended up being a bad ignition coil.
93YJ 4.8L Vortec,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 33" BFG KM2 T/A's with MT Classic II Wheels, Herculined Inside, Electric Fan, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bushwacker Extended Flat Fender Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline
post #5 of 25 Old 04-19-2013, 08:49 AM
Que89YJ
Cycle the key and listen for the fuel pump to cycle. If the fuel pump doesn't come on post back. There is a common issue with the fuel pump ground.
Que89YJ is offline
post #6 of 25 Old 04-20-2013, 05:06 PM Thread Starter
Idawg67
1992 TJ Wrangler
THANKS FOR THE WELCOME !!
Okay, so ity could still be something wrong re: the computer, but it is not reading it...
I have fuel pumping and filter is allowing fuel thru. I hear there was another smaller fuel filter inline between the first and the engine by the frame?? I am a Land Cruiser person, and use this as a daily driver...
Would a bad engine ground cause rough running ?? And allow it to die then immediately restart ??
Fuel pump cycles, and I have fuel flowing out of the filter... Due to rusting brackets and such, Ima a lil hesitant to replace it.. But I know it flows, so it SHOULD be good
BTW, I LOVE vBulletin forums... I have been admining them for YEARS, both at the corporate level and for my web clients
Idawg67 is offline
post #7 of 25 Old 04-20-2013, 05:58 PM
Rproject
1987 YJ Wrangler
The filter you're looking for is just in front of the rear driver's side tire on the frame rail. There's a clap type housing the holds it in and provides protection from flying debris.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 25 Old 04-20-2013, 06:14 PM Thread Starter
Idawg67
1992 TJ Wrangler
Yeah, I know about that one, but someone told me there was another in the system under the rig... MAYBE it was on an older one cause I have driven myself crazy looking for the second one LOL
Idawg67 is offline
post #9 of 25 Old 04-20-2013, 06:40 PM
Rproject
1987 YJ Wrangler
The older ones have a filter in the engine bay, about 12" before the carb.
1996 White ZJ
Rproject is offline
post #10 of 25 Old 04-20-2013, 06:58 PM
Que89YJ
Fuel assumed good for now do you have good spark at the plugs?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #11 of 25 Old 04-21-2013, 07:27 PM Thread Starter
Idawg67
1992 TJ Wrangler
I have a friend that is a mechanic and he will come by tomorrow and take a look... Will keep the thread updated
Idawg67 is offline
post #12 of 25 Old 04-21-2013, 07:43 PM
Squirrel442
Through vibration or when you hit a bump yes, my guess would be one of the sensors is going out. For some reason they don't always throw a code.
post #13 of 25 Old 04-21-2013, 08:34 PM Thread Starter
Idawg67
1992 TJ Wrangler
When I started up on Sat Morning, it would run rough for about 5 seconds then completely die... Now it wont start at all...
Idawg67 is offline
post #14 of 25 Old 04-22-2013, 12:06 AM
Snakebite22
It's a bad computer bro same happened to me you can try replacing the caps or just get a new one
Snakebite22 is offline
post #15 of 25 Old 04-22-2013, 06:33 AM
Que89YJ
With a no start you always check fuel at the fuel rail schrader valve and for spark at the plugs first.
Que89YJ is offline
