Have you ever seen this before...starting issues - Page 2 - JeepForum.com
post #16 of 35 Old 09-11-2013, 08:42 PM
Que89YJ
Could be. Replace it and battery reset.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 35 Old 09-11-2013, 08:47 PM Thread Starter
DTR
Could other sensors cause an error 24? I am awaiting a new o2 sensor...just don't want to replace every sensor to only have the same problem.
Thank you for your help
DTR is offline
post #18 of 35 Old 09-12-2013, 03:09 AM
Que89YJ
Map maybe. You can check the tps with a meter.
Fault codes:
No Start:
Que89YJ is offline
post #19 of 35 Old 09-13-2013, 09:01 PM
pete1991YJ
Originally Posted by DTR View Post
I already cleaned the IAC a few weeks ago...I wonder if I messed up the TPS...I cleaned it also.
Maybe try wiggling the wires going into the TPS, see what happens. How is the connector there, is it solid?
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #20 of 35 Old 09-13-2013, 10:22 PM Thread Starter
DTR
Good point, the plastic clip which locks it in place is broken off
DTR is offline
post #21 of 35 Old 09-18-2013, 01:26 PM Thread Starter
DTR
Well so far so good, I just install the O2 sensor. Jeep Seems to be running good but idling a little higher than normal around 950. Check engine light did come on right after I started it, I turn it off then restarted it and so far it has stayed off...we'll see what happens. Thanks again for all your valuable input
DTR is offline
post #22 of 35 Old 09-18-2013, 06:30 PM
pete1991YJ
950 is about right when its cold, see what it does when it gets good and warm. The light came on but there is no codes?
post #23 of 35 Old 09-18-2013, 06:52 PM
Que89YJ
How did you figure the o2 sensor was bad? I usual ask because the symptom is a difference between the way it runs hot and cold. Did you disconnect the battery after you replaced the sensor?
Fault codes:
No Start:
Que89YJ is offline
post #24 of 35 Old 09-18-2013, 09:58 PM Thread Starter
DTR
The light did come back on but this time I have no starting issues after it is hot. Getting error 24 again...I ordered a new tps. Hope this fixes it, seems to run ok
DTR is offline
post #25 of 35 Old 09-19-2013, 03:32 AM
Que89YJ
Ok. Tps should do it.
Fault codes:
No Start:
Que89YJ is offline
post #26 of 35 Old 09-19-2013, 09:02 AM
Siva283
Have you checked for vacuum leaks as well. When I did my engine swap (Que and Pete got me through it) I broke a vac line and was having trouble finding a replacment as it was the molded line. Soooo I capped it off on the throttle body until I could find a new one. Capping it off caused me to keep getting the code for the TPS. Once I made a vac line to fit it and reset the ECM no more code and she has run flawlessly since.
Ask me how I know...
Siva283 is offline
post #27 of 35 Old 09-19-2013, 11:45 AM Thread Starter
DTR
Thank you Siva...so I went and inspected all of my vacuum Lines and I did not see any physical cracks . I disconnected the vacuum line that runs off the manifold to the firewall and plugged it. Restarted the engine the check engine light did not even come on this time, what is the purpose of this vacuum line? And is it needed...seems like all my heater controls work properly Name:  image-557589682.jpg
Size:  425.8 KB Also the white cap you see is a plug… I installed a positive lock a while back Is it just a coincidence the light went off after I blocked this vacuum line… Would this cause the check engine light not to show error 24 I appreciate everybody's help, thank you so much
DTR is offline
post #28 of 35 Old 09-19-2013, 12:22 PM Thread Starter
DTR
Thank you Siva...so I went and inspected all of my vacuum Lines and I did not see any physical cracks . I disconnected the vacuum line that runs off the manifold to the firewall and plugged it. Restarted the engine the check engine light did not even come on this time, what is the purpose of this vacuum line? And is it needed...seems like all my heater controls work properly Also the white cap you see is a plug… I installed a positive lock a while back Is it just a coincidence the light went off after I blocked this vacuum line… Would this cause the check engine light not to show error 24 I appreciate everybody's help, thank you so much
Scratch my last posting...
Went back out to check the engine again, the check engine light stayed on so looks like I'm back to step one with the Error code 24. When I first started it I was getting lots of fluctuation in the engine idle like it was surging then dying almost then surging and dying...eventually it leveled out but the check engine light is still on.
I have a new TPS sensor on order should be here tomorrow.
DTR is offline
post #29 of 35 Old 09-19-2013, 12:50 PM
Que89YJ
DTR did you ever check the resistance or voltage on the tps. There are many youtube videos on doing it. This thread has how to test it:
http://www.jeepforum.com/forum/f12/t...p-asap-349207/
Que89YJ is offline
post #30 of 35 Old 09-19-2013, 01:51 PM Thread Starter
DTR
DTR did you ever check the resistance or voltage on the tps. There are many youtube videos on doing it. This thread has how to test it: http://www.jeepforum.com/forum/f12/t...p-asap-349207/
No do not have one, and don't know how to use one.
DTR is offline
