-   -   Have you ever seen this before...starting issues (http://www.jeepforum.com/forum/f12/have-you-ever-seen-before-starting-issues-1572566/)
DTR 09-07-2013 12:32 PM
I am in need of some forum advice.
Ok...the jeep seems to be running and driving good but then the check light will come on and if i turn off the ignition it does not want to start again...just keep turning over and over...nothing.
Now, if I let it sit for 5-10 mins it will start again and in most cases the check engine light will come back on and repeat the same pattern (engine light on...turn off ignition and then wait 5-10mins to start again).
:confused::confused:
I have tried reading the engine trouble codes but I can't make any sense out of them.
Is this a fuel related issue...its like its not getting any fuel or perhaps too much fuel after its been turned off then back on.
Is there some type of reset that occurs in 5-10 mins after it has been turned off?
Anybody experience this scenario?
1993 2.5L manual 77k
rambo3489 09-07-2013 12:51 PM
Can you get the code number? If you post it here someone will be able to help you out much better.
Not me. Because well most of the work done to mine consisted of removing most anything with a sensor, or cutting the unused wired to the diagnostic plug. LOL
pete1991YJ 09-07-2013 12:53 PM
There isn't any kind of reset. What codes do you get, even if it makes no sense? Also: does it happen only when it warms up? Far as the fuel goes, the pressure should be 31 PSI at idle, 39 PSI with the vacuum line unhooked from the regulator. You can rent the fuel pressure tester at Autozone, or buy the kit from Harbor Freight pretty cheap.
DTR 09-07-2013 01:20 PM
Have attached the link to the engine code... took a video let me know if you can figure out what code this is showing thanks again for the help
http://youtu.be/1IaYRnRLP6E
I can see 12 and 55 I just don't know what's between them
DTR 09-07-2013 04:29 PM
Hi,
Yes I only have this issue after the jeep is warmed up after driving around. I still get the engine light when the engine is cold, but I am able to immediately started up without any issues. Once the Engine light kicks on the engine seems to stumble for a second and then catches itself and runs fine.
pete1991YJ 09-08-2013 06:44 AM
Originally Posted by DTR (Post 15883189)
Hi,
Thanks, that is a *huge* help. Usually that means the oxygen sensor is bad, because the computer won't read it until the engine is warmed up. The other code is probably a 33 but I would think there would be a o2 sensor code also.
DTR 09-08-2013 07:47 AM
How many O2 sensors are there? How can I tell which 1 is bad?
pete1991YJ 09-08-2013 01:54 PM
There's only one. Make sure the terminals are clean and pack them with dielectric grease when you put it all back together. I think the wrench size is 1-1/8 and its in the exhaust downpipe, like right next door to the oil pan on the drivers side.
DTR 09-08-2013 03:37 PM
Thanks...I will order a new 1. The one of the vehicle looks like it is 20 yrs old. Any brand better than the others?
superj 09-08-2013 03:49 PM
Bosch
pete1991YJ 09-08-2013 06:25 PM
Originally Posted by superj (Post 15886062)
Bosch
X2, Bosch. I think most of the original electrics on the YJ's were made by Bosch when they were new.
Que89YJ 09-09-2013 04:14 AM
When it won't start disconnect the battery for 10 seconds and try it. It resets the ecu. If it starts then post back.
DTR 09-11-2013 06:38 PM
Yes it will start back up after disconnecting the battery. But then I get the engine light immediately.
Looks like I am getting a 12, 33, 24 and 55.
Is 24 the only code to be concerned with?
24 - Fault in the throttle postion sensor circuit
I am I safe to say it's bad?
Seems to be idling ok but once I give it some gas it hesitates and sputters.
Que89YJ 09-11-2013 07:18 PM
Yes. You might want to clean the iac while you are doing the tps. Look on YouTube for doing both.
DTR 09-11-2013 08:19 PM
I already cleaned the IAC a few weeks ago...I wonder if I messed up the TPS...I cleaned it also.
The time now is 01:33 AM.
