Quantcast Hatch back won't clear 31 inch tire on tail gate. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hatch back won't clear 31 inch tire on tail gate.
Old 10-15-2003, 08:26 AM   #1
Birdawg
I put my hard top back on yesterday and found out that I can't open my hatch back all the way because it hits the spare 31" tire on the tail gate (yes while tail gate is opened). I have put a shim between the spare and its mount and can get the hatch open if I push on the tire. Kind of a pain. Can't shim more because the studs arn't long enough. What have you guys done to get around this??? Thanks for the suggestions.
Peter
1992 YJ 4.0 Liter HO I6
Sitting on a Rock in the Bay
Air Restrictor & Chicken Bones Gone,20 Gal.Gas Tank :) Audiovox CD Sound Bar, Front Tow Hooks. Hard & Soft
Tops. 31" x 10 1/2" x 15" Coopers
Sumer Projects:2 1/2" Rubicon Express.(Done) New Metalic Paint.(Done)
31" Tires (Done), Bed Liner. Dome Light for Soft Top
[color=blue]Blue Jeep Member #15[/color]
Birdawg is offline   Reply With Quote
Old 10-15-2003, 12:25 PM   #2
Big Blue Jeep
Big Blue Jeep's Avatar
open the tail gate first then the hatch. Thats what i do. I have a 33" spare. Dont think there is any other way around it.
Matt
1991 "Big Blue" YJ 4.0L HO
4" Pro Comp Suspension Lift
Rancho 9000 shocks in the rear
Detroit locker in the rear
33x14x15 Super Swampers Boggers (summer tires)
33x12.50x15 Yokohama Geolander MT's ('winter' tires)
Custom push bar
8,000 lb Warn winch
Custom spot lights
Cherry Bomb Muffler
ARB snorkel
Big Blue Jeep is offline   Reply With Quote
Old 10-15-2003, 12:27 PM   #3
Big Blue Jeep
sorry i miss read your post. I dont have any clearance issues. I just have to make sure the door is fully open, or else i will hit the spare.
Custom push bar
8,000 lb Warn winch
Custom spot lights
Cherry Bomb Muffler
ARB snorkel
Old 10-15-2003, 12:42 PM   #4
RCHavok797
I had the same problem when I put my 31 inch spare on. I took a dremel and cut the right corner of the hatch just enough to allow it to clear the tire.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline   Reply With Quote
Old 10-15-2003, 01:10 PM   #5
E_ROCK
Peter
I am assuming that it hits the tire bump stop on the passenger side of the jeep. Does anyone make a smaller stop?
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Reply With Quote
Old 10-16-2003, 12:08 PM   #6
jeepnewbe
I had this same exact problem. I just took the spare tire mount and rotated it 180 deg. You have to drill one hole in the mount or you could leave the center bolt out but either way it will lower the spare tire about 5". I also ended up taking the bottom rubber bumpers off the tail gate and mounting them where the tire meets the bumper. Simple and costs only the half hour to do it.
jeepnewbe is offline   Reply With Quote
Old 10-16-2003, 01:24 PM   #7
CuzzinOlaf
I have 31x12.5s and a spare to match. I used this:
http://www.quadratec.com/cgi-bin/sgin0101.exe?UID=2003101614204041&T1=22202%2B03&UR EQA=1&UREQB=2&UREQC=3&UREQD=4&FNM=11&x=40&y=41
and was able to mount my spare on the back. I have to open the rear door all the way before I can open the glass but it works fine.
Hope this helps.
[COLOR=yellow][B]Cuzzin O[/B][/COLOR][B]
[COLOR=navy]Blue Jeep Club Member #27[/COLOR][/B]
[URL=http://images.cardomain.com/member_images/3/web/459000-459999/459189_5_full.jpg]MIGHT BE FS in NJ: 91 YJ 4.0 L w/5 Spd w/31x12.5 XTerrains on Canyons w/ 6" BW Flares [/URL]
[URL=http://memimage.cardomain.net/member_images/3/web/459000-459999/459189_21_full.jpg]YJ and WJ (before totalled) [/URL]
[B]Huge mud holes are like hot chicks with an STD. You want to hit them hard and fast but you’re afraid of the consequences[/B]
CuzzinOlaf is offline   Reply With Quote
Old 10-16-2003, 06:28 PM   #8
mUD uCKeR
Get a roof rack... Put tire on roof rack. That's gonna be my solution with 35's anyways. I already of a rack on top.
mUD uCKeR is offline   Reply With Quote
Glock Forum
