Has anyone used a LUK clutch kit? - Page 2 - JeepForum.com
post #16 of 34 Old 10-29-2011, 06:46 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
LUK is the OEM clutch for your jeep I have it in both of my jeeps and wouldn't use anything else.
My first clutch got over 200,000 miles on it; why would I use anything else.
I have no experience with the Gold version, just the standard LUK OEM replacement clutch.
Buy a new pressure plate while you are at it.
www.dialaclutch.com has fair prices on the LUK products.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #17 of 34 Old 10-29-2011, 07:38 PM
mighty4banger
I have one and also highly recommend!
It has held up to years of abuse. Good stuff
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline
post #18 of 34 Old 10-29-2011, 11:43 PM
fratis
fratis's Avatar
ive got a centerforce oem level unit (not the dual friction thing) its been in for quite a few years and although it seems fine, ive got the trans out for other reasons so i think im going to go with max on this one and put a luk in it.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #19 of 34 Old 10-30-2011, 04:01 PM
wendell
1987 YJ Wrangler
Luk is a good stock clutch. After I built my 258, I went with center force to handle the added power. But Luk served me well for years.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #20 of 34 Old 12-24-2011, 07:03 PM
msowka
Luk pro gold for a '05 2.4L?
It doesn't seem like luk makes a pro gold for the 2.4 powertechs... Are you suggesting my peppy 2.4 does not need a PERFORMANCE clutch??
On a serious note, I'm pretty peeved that after buying an otherwise mint '05 2.4 some time ago, the clutch would start slipping at 80000 KM (50000mi)! Could it be that this is something else (failin hydraulic actuation?), or maybe it has one of those shoddy Sachs units.
As I pointed it I got it 2nd hand, and it appeared to me a 'cityslicker' with puny tires. (ive since replaced these with 255/70r16 ~31 wheels, which makes the clutch situation more urgent.) I doubt that it had seen any serious off roaring... But even then 50000 miles for a clutch??!
Wishing skill & means to do the job himself,
Mike
msowka is offline
post #21 of 34 Old 12-24-2011, 08:43 PM
WindsorRenegade
That doesn't seem right, Mike. Does it happen all the time now or just once in a while?
Maybe the PO just didn't know how to drive stick. A bad driver can kill a clutch in an hour. How was it when you got it?
WindsorRenegade is offline
post #22 of 34 Old 12-24-2011, 09:09 PM
msowka
When I got it I did not notice a thing, until the winter in cold weather I would notice it slip when I would floor it. Now, year later, cold weather again it's real bad; I'm having to be VERY gentle on gas and accelerate in lower gears, otherwise it just spins up.
So, to be clear, it's there all the time, and as I wrote the above pangs of guilt hit me... (although it's hit critical state with larger tires suddenly). I will be getting into the shop right fret Xmas.
What kind of things should I keep in mind when I take it in?
Thanks & merry Xmas!
Mike
msowka is offline
post #23 of 34 Old 12-24-2011, 09:47 PM
jsawduste
2006 YJ Wrangler
Luk has a good reputation. I`d use one with no heartburn.
jsawduste is offline
post #24 of 34 Old 12-24-2011, 10:28 PM
msowka
Yeah, I'm sold on the brand, and hope that my shop carries it. When I got a quote for the job, they named another mnfr who's name I don't recall.
msowka is offline
post #25 of 34 Old 12-24-2011, 10:33 PM
jsawduste
2006 YJ Wrangler
Centerforce FTW
post #26 of 34 Old 12-24-2011, 10:49 PM
msowka
No centerpiece for the 2.4, can't handle the engines RAW POWER.
... <sarcasm>
msowka is offline
post #27 of 34 Old 12-25-2011, 07:42 AM
DallastheJeeper
Get the LUK standard and never look back. Best clutch I have felt in a Jeep.
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
post #28 of 34 Old 01-02-2012, 09:51 AM
97RustBucket
i'll assume most of you live in the states.... Luk clutch here in canada is just shy of $400, where as the centerforce clutch stage 1 is $280 avg. and the stage 2 is in the mid to high $300's.
97RustBucket is offline
post #29 of 34 Old 01-02-2012, 05:05 PM
ROWA
ROWA's Avatar
Mike
You might have moisture in the clutch fluid and during freezing conditions it will not let the throughout bearing release. Just a thought.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #30 of 34 Old 01-03-2012, 02:53 PM
40dog
sounds like a hydraulic issue water or failing master/slave cylinder. temp shouldn't effect the clutch disk or pressure plate. slushy fluid maybe water contamination
40dog is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 10:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 01:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 09:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 03:14 PM
