Has anyone used a LUK clutch kit? - JeepForum.com
post #1 of 34 Old 12-06-2009, 09:42 PM Thread Starter
jakechristina
I have to change the clutch and through-out bearing in my heep and was wondering about the LUK brand at Autozone.
jakechristina is offline
post #2 of 34 Old 12-06-2009, 10:09 PM
YJake
Mean Max here on the forum uses that set-up I believe.
I drove his Jeep and the clutch pedal was very strong! It felt as if I were using the clutch in a semi! Well... you get the point, it had plenty of resistance.
As far as performance goes he was very happy with it. I liked it too, you can actually tell when you're pushing in the clutch!
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #3 of 34 Old 12-06-2009, 10:13 PM Thread Starter
jakechristina
Thanks for the rsponce! Jake
By the way thats a great name!
post #4 of 34 Old 12-06-2009, 10:20 PM
Anonymous6915
2009 JK Wrangler
i too was persuaded by max to use a Luk clutch kit and im very happy i did.
Anonymous6915 is offline
post #5 of 34 Old 12-06-2009, 10:36 PM
btn2020
I put my luk in awhile back and have no complaints
Brian Nelson
1989 red stock yj 30in tires
btn2020 is offline
post #6 of 34 Old 12-06-2009, 11:31 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Jake
Yes, I do have a Luk clutch kit.
Yes, I am VERY happy with it.
Yes, it does have a very stiff pedal.
Now, I need to clarify something. The pedal on mine is stiffer because of the model Luk kit I used. They make 2 different clutch kits for many (not all) applications (listed below) and I used the 2nd one.
1) Luk RepSet = Original equipment (OEM) quality, stock pedal feel, lower cost.
2) Luk Pro Gold Series = "Performance" clutch with stronger pressure plate springs (reason for stiffer pedal) and also different clutch disc friction material. Priced slightly higher.
I found the best Luk prices at "motherclutcherz" on eBay. My Pro Gold kit was $224 including shipping to my door. This was the entire kit, pressure plate, clutch disc, throwout bearing/hydraulic slave unit, and 2 pilot shaft bearings (to accommodate either the .590" or .750" AX-15 input shaft) and 2 clutch alignment tools (to fit either pilot bearing) and a cool Luk sticker.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #7 of 34 Old 08-22-2010, 08:37 PM
rederer
LUK clutch pro gold
I just got a LUK clutch pro gold installed in my 03 tj, but now my 4wd won't engage, has anyone experienced this? and does anyone have any suggestions as to how to fix it?
rederer is offline
post #8 of 34 Old 08-22-2010, 08:41 PM
bob082484
I have the oe replacement one on mine and am very pleased with it. The pedal seems a little lighter than the stocker.
bob082484 is offline
post #9 of 34 Old 08-22-2010, 08:48 PM
dillonjm
2013 WK
I used one in the AX5 on my old 99 TJ.
I was very happy with it. Mine was a little stiffer than stock, but I can't remember which option (if there were any at the time) I went with.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #10 of 34 Old 08-22-2010, 08:49 PM
dillonjm
2013 WK
I would bet that the 4wd linkage is binding because of improper reinstall after dropping the tranny to put the clutch in.
dillonjm is offline
post #11 of 34 Old 08-22-2010, 08:58 PM
Krochus
Had one in my jeep for 5 years now with nary an issue cept for that one time the trans bolts came up missing.
IIRC luk is one of the largest suppliers of OE clutches out there.
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #12 of 34 Old 08-23-2010, 06:50 AM
19OlllllllO41
19OlllllllO41's Avatar
I have always heard that the factory clutches in Wranglers were all LUK brand clutches. Could be a rumor, I'm not 100% sure.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #13 of 34 Old 08-23-2010, 07:15 AM
monkeyhouse
Honestly(and no offense to anyone here) if Max recommends it, I am sold!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #14 of 34 Old 10-29-2011, 03:58 PM
DallastheJeeper
Some are sachs and they are trash!!!
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
post #15 of 34 Old 10-29-2011, 04:24 PM
copleydad
copleydad's Avatar
x2
'89 Islander 4.2l 5 speed
'14 Grand Cherokee Limited 3.6
One Jeep is Never Enough
copleydad is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
