-   -   Has anyone used a LUK clutch kit? (http://www.jeepforum.com/forum/f12/has-anyone-used-luk-clutch-kit-919060/)
jakechristina 12-06-2009 09:42 PM
I have to change the clutch and through-out bearing in my heep and was wondering about the LUK brand at Autozone.
YJake 12-06-2009 10:09 PM
Mean Max here on the forum uses that set-up I believe.
I drove his Jeep and the clutch pedal was very strong! It felt as if I were using the clutch in a semi! Well... you get the point, it had plenty of resistance.
As far as performance goes he was very happy with it. I liked it too, you can actually tell when you're pushing in the clutch!
Jake :tea:
jakechristina 12-06-2009 10:13 PM
Thanks for the rsponce! Jake
By the way thats a great name!
Anonymous6915 12-06-2009 10:20 PM
i too was persuaded by max to use a Luk clutch kit and im very happy i did.
btn2020 12-06-2009 10:36 PM
I put my luk in awhile back and have no complaints
Mean Max 12-06-2009 11:31 PM
Jake :tea:
Yes, I do have a Luk clutch kit.
Yes, I am VERY happy with it.
Yes, it does have a very stiff pedal.
Now, I need to clarify something. The pedal on mine is stiffer because of the model Luk kit I used. They make 2 different clutch kits for many (not all) applications (listed below) and I used the 2nd one.
1) Luk RepSet = Original equipment (OEM) quality, stock pedal feel, lower cost.
2) Luk Pro Gold Series = "Performance" clutch with stronger pressure plate springs (reason for stiffer pedal) and also different clutch disc friction material. Priced slightly higher.
I found the best Luk prices at "motherclutcherz" on eBay. My Pro Gold kit was $224 including shipping to my door. This was the entire kit, pressure plate, clutch disc, throwout bearing/hydraulic slave unit, and 2 pilot shaft bearings (to accommodate either the .590" or .750" AX-15 input shaft) and 2 clutch alignment tools (to fit either pilot bearing) and a cool Luk sticker.
Max :cheers2:
rederer 08-22-2010 08:37 PM
LUK clutch pro gold
I just got a LUK clutch pro gold installed in my 03 tj, but now my 4wd won't engage, has anyone experienced this? and does anyone have any suggestions as to how to fix it?
bob082484 08-22-2010 08:41 PM
I have the oe replacement one on mine and am very pleased with it. The pedal seems a little lighter than the stocker.
dillonjm 08-22-2010 08:48 PM
I used one in the AX5 on my old 99 TJ.
I was very happy with it. Mine was a little stiffer than stock, but I can't remember which option (if there were any at the time) I went with.
dillonjm 08-22-2010 08:49 PM
I would bet that the 4wd linkage is binding because of improper reinstall after dropping the tranny to put the clutch in.
Krochus 08-22-2010 08:58 PM
Had one in my jeep for 5 years now with nary an issue cept for that one time the trans bolts came up missing.
IIRC luk is one of the largest suppliers of OE clutches out there.
19OlllllllO41 08-23-2010 06:50 AM
I have always heard that the factory clutches in Wranglers were all LUK brand clutches. Could be a rumor, I'm not 100% sure.
monkeyhouse 08-23-2010 07:15 AM
Honestly(and no offense to anyone here) if Max recommends it, I am sold!
DallastheJeeper 10-29-2011 03:58 PM
Some are sachs and they are trash!!!
copleydad 10-29-2011 04:24 PM
x2
The time now is 03:24 PM.
