has anyone swap for a Chrysler 8.25? - JeepForum.com
post #1 of 3 Old 04-25-2002, 01:21 PM Thread Starter
bighair
Hey guy's,
Has anyone ever tried a rear axle swap for a Chrysler 8.25? I think it coems off of a grand cherokee? not too sure but has anyone tried it??
Thanks guy's
Team Mod Squad
We are here to help YOU!
bighair is offline
post #2 of 3 Old 04-25-2002, 02:53 PM
RodeoRob
RodeoRob's Avatar
swap out the D35c for the Chrysler 8.25? Not gaining too much with this swap IMHO... not nearly worth it. The 8.25 isn't as good of an axle when compaired to a D44 or Ford 8.8. Also, aftermarket support (gears, lockers) isn't nearly as abundant in Chrylers axles as it is in Danas.
Anyway, 8.25's are found in many XJ's, they should be hard to come across. I'm not sure if they're found in low end ZJ/WJ's, but high end ones come with D44s.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 3 Old 04-25-2002, 03:02 PM Thread Starter
bighair
yeha I wasn't sure about the 8.25 cause I haven't heard much about them.. I was just curious.
I'm actually looking for 80-84 Cherokee so I can mach up the front and rear with D44's and both the same bolt pattern and the Cherokee in these years have the drivers side drop.. and swaping both, both axles will be the same width. which if I swapped a ford 8.8" and the D44 front. they may not be the same width or bolt pattern or gear ratio.. hehe
I'm still researching lots so I'lll be more comfortable hehe
Thanks for the info
Team Mod Squad
bighair is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Chrysler would like to know ? slow2run Wrangler General Discussion 90 08-22-2009 11:52 AM
Chrysler 8.25 under a tj sed8ed TJ Wrangler Technical Forum 5 05-16-2008 07:01 PM
Chrysler VIN llbrown6 TJ Wrangler Technical Forum 5 01-11-2007 01:23 PM
Chrysler 8 3/4 Swap??? Good idea?? Lud04X TJ Wrangler Technical Forum 4 05-19-2005 08:23 AM
