has anyone heard of putting glass beads in large tires? - JeepForum.com
post #1 of 22 Old 12-04-2008, 02:39 PM Thread Starter
chadroc
I had my 37" MTRs mounted and they took a lot of weight. I'm not even sure they were able to balance them very well. One of the guys at the tire shop suggested I put a couple ounces of glass beads in the tires. Any idea what he's talking about!
chadroc is offline
post #2 of 22 Old 12-04-2008, 02:44 PM
yjcrawlr
I haven't heard of glass. People do use air soft pellets. Other products are available. The guy might be talking about beads for etching glass.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #3 of 22 Old 12-04-2008, 02:44 PM
mgramann
I've heard of balancing sand. I bet its the same thing.
mgramann is offline
post #4 of 22 Old 12-04-2008, 02:47 PM
joelwg
2005 WJ
What is the reason for it though? Too take up volume inside the tyre or centrifugal weight?
joelwg is offline
post #5 of 22 Old 12-04-2008, 02:56 PM
mcgann454
Check this out.
http://www.innovativebalancing.com/
http://www.counteractbalancing.com/
93 YJ Full Restore
4" Lift
1" Body
33" BFG's
97 TJ Full Restore
3" Suspension Lift
1" body lift
33" BFG's
97 TJ Engine swap
2000 4.3L Vortec
4L60E
231c with Slip Yoke
2.5" suspension lift
1.5" body Lift
Still got to paint
mcgann454 is offline
post #6 of 22 Old 12-04-2008, 03:06 PM
joelwg
2005 WJ
If they ballance through centrifugal force then, will it sound a bit like a babys rattle when you start to slow down?
joelwg is offline
post #7 of 22 Old 12-04-2008, 03:16 PM Thread Starter
chadroc
Originally Posted by mcgann454 View Post
Yeah, that sounds like what he was talking about. He said glass bead.... but they could have just as well been ceramic. I've never heard of that before but it sounds like I might need them.
chadroc is offline
post #8 of 22 Old 12-04-2008, 03:19 PM Thread Starter
chadroc
It's inside a tire. I don't think bead would make much noise. If we were friends and you put them in your tires, I would probably crawl under your jeep when you werent around and duct tape little rattles to the inside of your wheels just to **** with you!
chadroc is offline
post #9 of 22 Old 12-04-2008, 03:22 PM
dbikers
i've heard of bb's (for a bb gun...you'll shoot yer eye out).
maybe the "glass bead" would be like the media for a bead-blaster (like a fine glass sand)..
i have 33's and haven't done this ...a few of my friends have 35's and haven't had to do it either (but they have lifetime balance and take it in twice a year just for good measure).
STUPID HURTS.......OUCH!@#$
dbikers is offline
post #10 of 22 Old 12-04-2008, 03:28 PM
ritjobbie
I have no weights on my rims and have only balanced with airsoft BBs on my last two sets of tires. No wobble up to 60mph, too scary to go faster than that in a Jeep. My last tires were 33x12.5 bias TSLs, currently on same size trXus MTs, both on 15x10 steelies. I had steel BBs in the TSLs and they didn't rust or anything, but you could hear them hit the rim when I stopped. I went with airsoft this time and they are waaaay quieter. I can't even tell that the airsoft pellets are there. I used camouflage air soft pellets, so that might have something to do with the extra stealth...
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #11 of 22 Old 12-04-2008, 03:30 PM
mcgann454
I did some research on this and there was a thread on this a while ago. A lot of people were just using a bottle of the Airsoft pellets and had good results. I did not do it at the time because I balance twice a year(free at Discount Tire).
Found the thread
http://www.jeepforum.com/forum/showt...alancing+beads
93 YJ Full Restore
4" Lift
1" Body
33" BFG's
97 TJ Full Restore
3" Suspension Lift
1" body lift
33" BFG's
97 TJ Engine swap
2000 4.3L Vortec
4L60E
231c with Slip Yoke
1.5" body Lift
Still got to paint
post #12 of 22 Old 12-04-2008, 04:40 PM Thread Starter
chadroc
That's dangerous. and irresponsible. Both to yourself, your passengers and others. Someone may not even see you coming with those camo airsoft pellets in your tires.
Seriously now.... That works? That's amazing! Airsoft are the plastic bb's right? Why is your jeep so bad at with speed though? Mine sucks a lot of gas and has a lot of wind noise at 80, but it's otherwise comfortable.
chadroc is offline
post #13 of 22 Old 12-04-2008, 04:58 PM Thread Starter
chadroc
Found the thread
Thanks for that info. If my tires don't seem balanced very well, I'll try that. I won't know til spring. That jeep doesn't like salt. (actually it's never had it before and I'd like it to stay that way!)
chadroc is offline
post #14 of 22 Old 12-04-2008, 05:40 PM
joe's_yj
joe's_yj's Avatar
does the air soft bb's fit through the valve stem if you take the core out?
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #15 of 22 Old 12-04-2008, 05:44 PM
ritjobbie
I have an Aussie Locker in my D35. It adds some 'manners' at higher speeds. =) I guess I'm just super sensitive to having sloppy suspension compared to my Subaru. Track arms make a difference on highways.
I used .12gram plastic airsoft BBs. Guys on the forum recommend heavier BBs, but I couldn't find the .20gram or heavier ones locally after 9pm when I got around to putting them in. The only thing that sucks about air soft or other BBs vs. dynabeads or something smaller is that you have to break a bead to put them in. If you don't have a nice air supply, airing your tires back up could be a non-trivial task. My 26 gallon compressor works just fine for reseating tire beads. Smaller beads can go through the valve stem after you pull the core, which saves about 2 minutes of work. Meh.
YMMV
tires balanced, with beads? goldswim5 TJ Wrangler Technical Forum 7 01-02-2009 01:14 PM
putting glass in new windshield YJ_95 YJ Wrangler Technical Forum 2 05-21-2008 07:00 PM
Large tires '95 wrangler? whattakick YJ Wrangler Technical Forum 10 04-07-2007 04:31 AM
Large tires on JK Fat_Man JK Wrangler Technical Forum 2 05-05-2006 02:19 PM
Gas mileage for 2.5L with large tires dcel22 TJ Wrangler Technical Forum 19 03-02-2003 03:34 PM
