has anyone ever lifted a jeep this way - Page 2 - JeepForum.com
post #16 of 20 Old 05-03-2010, 11:00 PM
BlackRhino
BlackRhino's Avatar
I see tons of trucks around here with lift blocks, some longer than 12"! That's just an accident waiting to happen. As has been said though, they only work SOA.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #17 of 20 Old 05-04-2010, 12:32 AM
samsonitesamson
Even the small ones that comes stock on some trucks just exacerbate (Sp?) axle wrap.
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
post #18 of 20 Old 05-04-2010, 07:05 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
look under your jeep.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #19 of 20 Old 05-04-2010, 07:28 AM
YJhobby
If you want it lifted cheaply, then you will regret it.
Basically you have to get some combination of lift springs, shackles and body mounts to lift it. There are really no other ways other than to Spring Over Axle (SOA).
Most will recommend that you start with some mild shackles (1/2"-1" of lift) and a mild body lift (1"-2") These both need to be mild in lift height because big lifts in either of these areas will adversely effect your ultimate goals.
With a 1" daystar BL you'll replace stock mounts with extended poly mounts, and with a set of greasable shackles you'll have more flex. These two mods will cost you about $300 total and you'll be much better off than any blocks ever could get you!
Also ditch the track and sway bars and your ride will improve.
~Steve~
Originally Posted by SnowdogMarc
YJ's don't get stuck....they get temporarily impeeded in their forward progress.
I'm patiently waiting for the "foot-in-mouth" moment to end... but since I've posted, its not today
YJhobby is offline
post #20 of 20 Old 05-06-2010, 03:41 PM Thread Starter
yjripper
im not planning on a cheap lift because i dont want to fix and re-fix. somebody just brought it up and i was skeptical but just wanted to see what everyone though
yjripper is offline
How do I know if my Jeep is lifted and how much? ctsvmongo YJ Wrangler Technical Forum 10 08-07-2015 07:30 PM
Looking to buy a lifted Jeep. I have ?s quintessence08 TJ Wrangler Technical Forum 11 04-05-2010 08:59 PM
Got the jeep lifted yjweeler YJ Wrangler Technical Forum 15 10-11-2009 10:05 AM
Is my jeep lifted? reed338 TJ Wrangler Technical Forum 32 09-01-2007 05:41 AM
Is my Jeep lifted? Antelope YJ Wrangler Technical Forum 9 11-16-2004 06:59 PM
