Has anyone done this... Is it even do-able - Page 2 - JeepForum.com
post #16 of 31 Old 05-27-2013, 07:51 AM
befumo
Originally Posted by CBinDC View Post
Also if you go with an aftermarket carb, you can get rid of that POS stock air filter. A nutter and another carb will clean up the bay pretty good!
Yeah when i switched to the Weber, new air filter and removed pulse air lines. Engine bay looks so much better!
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #17 of 31 Old 05-27-2013, 08:11 AM
CBinDC
It really does. This is the way to go if you want to make the bay less cluttered looking.
CBinDC is offline
post #18 of 31 Old 05-29-2013, 08:54 AM Thread Starter
jeepinjames20
jeepinjames20's Avatar
Yea in regards to how bad they were. Try pitch black. Lol. Got the tune up parts about to start that now.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
Firefighters Jeep Club
Build...Run...Break...Repair...Repeat...
jeepinjames20 is offline
post #19 of 31 Old 05-29-2013, 09:47 AM
Que89YJ
A few things Jeepin James. Tools like the timing light can be rental with a fully refunable deposit from any of the big autoparts store tool loaner programs. The nutterpass does have one omission if you reead into it. The distributor should have a seperate ground run for it. Doing a HEI ignition coil is a good mod giving you a hotter spark if you are running a slightly older engine to get a better burn with a engine that has a little more wear on the oil rings.
Que89YJ is offline
post #20 of 31 Old 05-29-2013, 11:03 AM Thread Starter
jeepinjames20
Ahh crap. How does this ground wire get run? Also, I may be breaking down and renting a timing gun soon lol.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
post #21 of 31 Old 05-29-2013, 11:14 AM Thread Starter
jeepinjames20
I also used 12 gauge wire, could that be where I'm loosing electricity and causing it not to start
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
post #22 of 31 Old 05-29-2013, 01:15 PM
Que89YJ
Black wire gets grounded to a good ground point. Most people have been taking it to the battery. Are you getting spark after the nutter?
Que89YJ is offline
post #23 of 31 Old 05-29-2013, 05:07 PM
jstatler
Did a nutter bypass on an 87 YJ. Worked like a champ. All the vacuum on about everything but the choke pull off and timing advance can be eliminated. You may need vacuum on an idol pick up if you have A/C.
jstatler is offline
post #24 of 31 Old 05-29-2013, 09:23 PM Thread Starter
jeepinjames20
Well, I got 'er started. Kind of... Turns out the timing was so off that it wasn't allowing the thing to start. Through trial and error we got it running but now, even though it purrs at idol it is running very rough when under load (Ie in gear) any ideas suggestions.
Also, the ground wire was still attached to the ignition module so that turned out to be a non issue for me.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
post #25 of 31 Old 05-30-2013, 05:21 AM
jstatler
Did you check that the timing is advancing as the rpm goes up?
jstatler is offline
post #26 of 31 Old 05-30-2013, 07:57 AM
vadslram
I have an HEI and an MC2100. The only hoses under my hood go to the dizzy, the brakes, the PCV and the 4wd. I also peeled back all the emissions wires, just gauges, power and tach left on the engine.
vadslram is offline
post #27 of 31 Old 05-30-2013, 08:01 AM
vadslram
If it runs good at idle but bad under load I would bet that the distributor vac advance is causing it. Exactly what is more difficult from here. Could be your advance is right and once the vac goes down the timing goes off. Could be the static advance weights are set wrong or in conjunction with the vac is going out of spec.
vadslram is offline
post #28 of 31 Old 06-04-2013, 10:33 PM Thread Starter
jeepinjames20
So here is where we stand as of right now. Today I spent the whole day going over the thing with a fine tooth comb. We pulled every plug, regaped (as I made the mistake of not gaping them right the first time) the spark plugs and she started up (roughtly). From there we found an exhaust leak (the tube that goes to the egr) and welded that up. Then we made sure all the vaccume lines were correct. After adjusting the air/fuel screws on the front of the stock webber she ran great! test drive was great (with the exception of two momentary incidents were it "popped" and lurched like it did before but not undriveable aside from that no issues). Then the bomb shell, I wanted to adjust my Idol screws a little to help step it up a bit and my friend noticed that the carb wasn't bolted down all the way (two out of the four nuts were loose) so he tightened them down for me.... Thinking we were finally done, that we fixed all the issues that were causing the one big issue, we were disheartened to find out the jeep wouldn't start again. My friend seems to think that it was causing such a huge vac leak and pressure issue that the timing is off again. So we tried to start the jeep while I slowly twisted the distributor cap and it seemed to want to start but by that point we flooded the engine and called it quits for the night.
Any thoughts? could a vaccume leak/pressure leak at the carburator cause the timing to be off as such? Other then that one last thing we "adjusted" (aka made right), we can't think of what went wrong!
Any input is greatly appreicated.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
post #29 of 31 Old 06-05-2013, 03:30 AM
jstatler
If you marked the timing put it back where it was running. Look at the choke. All the rods and the pull off. If the choke doesn't reset, it will not start. Could have messed it up tightening down the carb.
jstatler is offline
post #30 of 31 Old 06-05-2013, 12:06 PM Thread Starter
jeepinjames20
Update: It was the timing, jeep is running GREAT now, I can't speak highly enough of the Nutter bypass. Once we backtraced all the vac leaks, ensured good spark etc it solved the majority of the issues. I couldn't be happier with the results.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
