Has anyone done the 4.0l swap using a YJ harness - Page 2 - JeepForum.com
post #16 of 19 Old 01-12-2007, 05:38 PM Thread Starter
ID89YJ
ID89YJ's Avatar
No, you can use the cherokee harness, you will splice your engine harness into the cherokee harness.
The only reason i used a wrangler harness is because i found one at the wrecking yard that i got my engine from.
http://www.madois.com/html/tech/40swap.html
That link will tell you what to do.
Steve
1989 Wrangler... 93 4.0L , AX15 ,231 TC,Rough Country 4inch lift, 33 12.50 Baja Claws .
ID89YJ is offline
post #17 of 19 Old 01-12-2007, 09:04 PM
crb577
mine is a little different scenario but I did use a YJ harness when I did a 2.5L to 4.0L swap. but mine was all plug and play. No splicing required. I have a '95YJ that had the 2.5L in it and I used a '94 motor took about 2 weeks to get running again runs and works great.
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #18 of 19 Old 01-12-2007, 09:37 PM Thread Starter
ID89YJ
ID89YJ's Avatar
Mine had a 2.5l aswell, i wish mine would have been closer to the same year it would have made the job alot simpler.
Steve
ID89YJ is offline
post #19 of 19 Old 01-20-2012, 11:16 AM
Keepajeep
I am looking for the interior firewall connections for a 1994 2.5L YJ interior harness to a 1991 YJ 4.0L engine harness. 10 pin connector. can't find anything ?
thanks for any help diection
Jake Bondy,Sarnia, ON Canada
Build it, Break it, Fix it, Replace it, REPEAT !!!!!!!!!!!! Jeep......A way of life
Keepajeep is offline
88YJ Wire Harness swap with XJ mmmkay325 YJ Wrangler Technical Forum 0 02-10-2010 01:56 PM
YJ Harness swap k9dave YJ Wrangler Technical Forum 1 11-19-2009 08:03 AM
5.3 swap wire harness chadroc YJ Wrangler Technical Forum 13 12-14-2008 08:24 PM
1990 YJ Engine Swap - Harness Q Fred007 YJ Wrangler Technical Forum 3 10-14-2007 09:22 PM
2.5 to 4.0 swap wiring harness.. mbe25 YJ Wrangler Technical Forum 16 03-17-2007 08:25 AM
