Harness issues - JeepForum.com
post #1 of 17 Old 04-05-2010, 06:01 PM Thread Starter
NOAKES91yj
Harness issues
I just swapped my 4cyl in my 91 for a 95 6cyl. Everything went pretty smooth considering the wiring harness came with it..... exceppttt that the plug in above the transmission hump that goes through the fire wall to my dash. The dash has 10 wires and the new 6cyl wiring harness has 13???
-Also, those were the only wires that were cut on the 6cyl harness so it doesn't have the plug-in on the end so i'm not sure what the plug-in would even looks like.
Maybe i am looking at it wrong i don't know but any help in that area would be greatly appreciated.
Thanks
Only in a Jeep
NOAKES91yj is offline
post #2 of 17 Old 04-05-2010, 06:15 PM
provinT13
Can you get a picture? I'm confused as to what you're talking about
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 17 Old 04-06-2010, 08:02 PM Thread Starter
NOAKES91yj
Well i've got them on my computer, i don't know how to load them on the site...??
Only in a Jeep
post #4 of 17 Old 04-06-2010, 08:51 PM
Mark05059
upload photos to a free hosting site (such as photobucket)... post the link to the picture (using the IMG tag) and someone will make them click free for you.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 17 Old 04-08-2010, 11:11 AM Thread Starter
NOAKES91yj
These are the 6cyl wires that went through the fire wall that were cut This is the old 4cyl plug in that went through the fire wall This is were the plug in from the 4cyl motor "shown above" went to under the dash
Only in a Jeep
post #6 of 17 Old 04-08-2010, 11:12 AM Thread Starter
NOAKES91yj
I just dont know what to do with the 6cyl cut wires since there are 13 of them and only 10 on the old 4cyl harness
Only in a Jeep
post #7 of 17 Old 04-08-2010, 07:13 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Thanks
For the '95 YJ the only plug I found so far that has 13 wires is for the headlamps. Look at the bulkhead connector mounted into the firewall. Plugging into that gets your wiring into the cab. I believe that you actually plug two plugs into that bulkhead connector. One for the engine and the other for the headlamps.
Does this list of wire colors match what you have?
BK/YL
BK/WT
TN
LG/WT
DB/WT
WT/OR
LG
LB
RD/OR
RD/GY
BR
DG/RD
VT/WT
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 17 Old 04-08-2010, 07:44 PM Thread Starter
NOAKES91yj
yes i have both of those plugged in but what am i supposed to plug in there under the dash?? and where do those cut wires go?
Only in a Jeep
post #9 of 17 Old 04-08-2010, 08:06 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
OK so that is your instrument panel connector. I can fget you some information on those wires some time soon. I am not at my tower PC which has all my stuff on it but my LT.
post #10 of 17 Old 04-08-2010, 08:25 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Ten of those wires will match color for color & pin for pin the wiring in the plug in the firewall. Get them seperated from that stub of wires. What color wires do you have left?
post #11 of 17 Old 04-09-2010, 06:39 PM Thread Starter
NOAKES91yj
Well i tried to match them up with colors and it wasn't happening but the guy that cut the wires on the 6cyl said that they went through the firewall where my old 4cyl wires went..?? I am troubled and confused with this
Only in a Jeep
post #12 of 17 Old 04-09-2010, 06:57 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
We forgot one thing. The harness inside your heep is a '91 harness. The harness you are using is for a '95 engine. You will need a wiring diagram for a 95 harness AND a wiring diagram for a '91 harness and compare them pin # to pin # instead of color
post #13 of 17 Old 04-09-2010, 07:07 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Ok here is the plug for the 1995 harness. It show the engine harness plug and the plug under the dash. Using the large red wire as an orientation point you should be able to match the cut wires to the plug under the dash since it only has one way to fit together if it was still there on the engine harness.
post #14 of 17 Old 04-11-2010, 10:03 AM Thread Starter
NOAKES91yj
Well i deffinatly appreciatte the help you are giving me, the wiring harness is in fact a 95 that is on the new 6cyl engine and the 4cyl i took out has the old 4cyl harness.
But the 6cyl does have 13 wires and the diagram you are showing (which is infact the correct one because i ended up finding it in the factory service manual) only has 10...?? i am going to try your theory and for the ones i don't know i'll play the old guess and check game lol.
Once again thanks a lot, hopefully i can get it going cause this weather is killing me not having my jeep running
Only in a Jeep
post #15 of 17 Old 04-11-2010, 10:27 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
First figure out the where the first ten wires go. Then we can work on what those final three are for. Do you already know which three wires are 'extra'?
The MAP sensor plug (#1 BK/LB sensor ground, #2 DG/RD sensor signal, #3VT/WT 5 volt supply). is in that area.
Like I said sort out what wiring goes to the dash harness plug and then figure out where those final three wires go to be determined by their colors.
4cyl to 6cyl harness swap , wiring harness
90 2.5L idle issues / desieling issues scottsea YJ Wrangler Technical Forum 2 09-18-2009 08:22 AM
Electical harness issues xjgnar TJ Wrangler Technical Forum 1 06-13-2009 10:20 AM
New problem, still dealing with electrical issues. UPDATED, STILL HAVE ISSUES!!!!! rustywrangler YJ Wrangler Technical Forum 34 02-17-2009 05:51 PM
Seats/Harness bar for 5 point harness Metzgerhund TJ Wrangler Technical Forum 18 04-04-2008 11:24 AM
Vacuum Harness Diagram issues Need Help doubleroost YJ Wrangler Technical Forum 7 12-28-2007 08:38 AM
