Hardwiring my winch to a switch in the cab - JeepForum.com
post #1 of 3 Old 02-24-2010, 11:08 AM Thread Starter
MWguy101
I have a Smittybilt XRC 8 Winch.
I was considering hardwiring the winch to a switch inside my cab and bypassing the remote switch that has a 12 foot cord.
Is this good idea or this a asking for trouble?
This is what the website has to say about the winch.
The new Smittybilt XRC 8 Winch encompasses all the best features you would want in a winch. Every XRC 8 (8,000 LB.) winch features a 5.5HP Series Wound Motor and a Planetary Gear System with 172.8:1 gear ratio that will deliver power and reliability at a premium price. For a recovery system with the muscle and dependability to bail you out of any situation, the XRC 8 has all the heavy duty toughness you're looking for.
Revolutionary planetary gear system boasts an 8,000 lb. line rating and 172.8:1 gear ratio
5.5 hp, 12-volt, series wound motor
5/16" x 92' galvanized aircraft cable with replaceable hook included
Intuitive design ensures a simple, hassle-free installation
A heavy duty winching system with great features at an incredible overall value
Drum size: Diameter/Length: 2.5" (63 mm) x 9" (228 mm)
Mounting bolt pattern: 10" x 4.5" (4 bolts, 3/8") (254 mm x 114.3 mm)
Overall Dimension (LxWxH): 21" x 6.22" x 7.283" (558.8 mm x 158 mm x 185 mm)
Total shipping weight: 94 lbs (42.5kgs)
All Smittybilt Winches meet SAE-J706 standard ratings for winches
MWguy101 is offline
post #2 of 3 Old 02-24-2010, 11:18 AM
sebastian22
I did it to mine and its been very useful, I've never even used the controller out on the trail, its much more convenient to just flip a switch on your dash and be done with it. You do need another set of eyes so that you dont suck in too much cable.
check out my winch thread linked in my sig.
edit: the way i wired it up, i can still use the remote if i need to, so it is not completely bypassed.
95 Black YJ
sebastian22 is offline
post #3 of 3 Old 02-24-2010, 11:22 AM
timatoe
timatoe's Avatar
Here's another, I've had stashed away for awhile..... http://www.jeepforum.com/forum/f12/c...ontrol-505012/
Here's what I did.... Now I just need the winch.
timatoe is offline
aftermarket horn wired to switch, would like stock to work on switch as well hilton00 TJ Wrangler Technical Forum 14 01-02-2010 02:11 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
Interior Winch Switch???? ET48 TJ Wrangler Technical Forum 17 03-16-2009 08:27 PM
Hardwiring XM to ignition KingofPop TJ Wrangler Technical Forum 25 10-16-2007 05:13 PM
Hardwiring the factory radio jreuscher TJ Wrangler Technical Forum 3 03-04-2006 10:40 AM
