Hardtop window - JeepForum.com
post #1 of 20 Old 02-10-2013, 08:56 PM Thread Starter
1990yjoffroad
Hardtop window
Any ideas where to get the rear hardtop window plastic piece, its on the bottom of the window with the handle. Mines destroyed and need a new. It's on my yj hardtop.
1990yjoffroad is offline
post #2 of 20 Old 02-10-2013, 09:10 PM
robx316
I'm not quite sure what you mean but.
Try calling Jack
My build thread
http://www.jeepforum.com/forum/f12/prolonged-yj-build-1470550
robx316 is offline
post #3 of 20 Old 02-10-2013, 10:59 PM
sloopie
I am in search of the same piece. About to make my own out of aluminum.
sloopie is offline
post #4 of 20 Old 02-10-2013, 11:48 PM
ROTTEN
Yup. Right in my back hall way!
Handle and everything works
Not sure what to ask for it though
Its available
I'm new
ROTTEN is offline
post #5 of 20 Old 02-11-2013, 07:25 AM
Shadownwpa
I have one too... leaning in the corner.
Shadownwpa is offline
post #6 of 20 Old 02-11-2013, 07:33 AM
Hoxie
Hoxie's Avatar
1987 YJ Wrangler
Just a heads up, I have made one out of Plexiglas from home depot. I used my old/broken one to trace an outline and cut it out with a dremel. If I were to do it again id use a jig saw and a dremel to clean up. My Dremel got super hot from all the cutting.
Heres a link to what I used. (I dont remember mine being that expensive. I think I spent around $70.) Good Luck!
http://www.homedepot.com/Building-Ma...%7C13087068693
YJOTM January 2017
Hoxie is offline
post #7 of 20 Old 02-11-2013, 07:34 AM
Hoxie
Hoxie's Avatar
1987 YJ Wrangler
Disregard my last post.... I thought you ment the window. I suck. lol
YJOTM January 2017
Hoxie is offline
post #8 of 20 Old 02-11-2013, 09:44 AM
ROTTEN
I just checked for mine . Its gone...
Booooo
I'm new
ROTTEN is offline
post #9 of 20 Old 02-11-2013, 02:47 PM
sloopie
So an update on my rear window situation. I'm not the OP but he has the same problem I do. I went to my local machine shop and he took measurements. He is cutting me out a frame for it and I will be using 1/4" Plexiglas in it. I picked up some hinges from the local lumber yard. Still thinking of ideas for a latch/lock. I will do a write up with pics next week or so.
sloopie is offline
post #10 of 20 Old 02-11-2013, 03:00 PM
rap169
I have a hardtop with a good back window. Hardtop is cracked but still useable. Ill sell the whole thing for $125
rap169 is offline
post #11 of 20 Old 02-11-2013, 03:06 PM
Rproject
1987 YJ Wrangler
Here ya go: http://www.jeep4x4center.com/parts-a...rdtop-seal.htm
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #12 of 20 Old 02-11-2013, 03:51 PM
Red93yj
2011 JK Wrangler
eBay is where I got it
Red93yj is offline
post #13 of 20 Old 02-11-2013, 03:58 PM
Shadownwpa
If I read right, the guy is looking for the fiberglass bars that sandwich the glass at the bottom end of the hatch... where the lift struts attach and some tops have the t-handle knob. I'd take the guy up on the $125 deal... just the glass will cost 170 unless you find it used like that, I paid 150 for my replacement back hatch. If you want cheaper I'll sell you the fiberglass bars for $30+shipping and you can put them together with plexi (should be held shut by the tailgate like normal so no latch)... or cheaper yet you can just go with the plexi and lumber store hinges
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
post #14 of 20 Old 02-11-2013, 04:27 PM Thread Starter
1990yjoffroad
The windows fine I just need the plastic pieces that sandwich the window together.
post #15 of 20 Old 02-11-2013, 04:46 PM
rap169
Back window and fiberglass bottom is good in the hardtop, off a 94
rap169 is offline
